Question about Dell Dimension 4700 PC Desktop
Brightness contrast control panel randomly appears on my screen, i have no control over this.i have access to the wiring at the bottom of the monitor panel, I want to id which ones to cut to remove the monitor control options
  • Anonymous Mar 30, 2014
    boots fine. problems function. White objects very bright with no contrast. Gamma / brightness / contrast controls function, but objects still difficult to distinguish in white areas of screen.
    Sergeant:
  • 244 Answers
Wouldn't do that! unless you want to replace your monitor! does it have a remote? is it coded infra-red, or uv? do you have compact florescent lights? could be stray signals are triggering your contrast/brightness function on your monitor. doubt that cutting a wire will help- may make your monitor unusable! try covering the sensor window on the monitor with masking tape, or something similar. if the problem persists- prob. a problem with monitor!
good luck!
Posted on Oct 09, 2009
  • 53 Answers
Never try that please beeter contact a tech for this
Posted on Oct 01, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How to view
Connect the power and data cables securely to the back of the monitor and the computer. Try plugging the computer and or monitor into another outlet to be sure there is no problem with the outlet. Go to the Control Panel and click on "System and Security" and then click on "Power Options. Click on "Change Plan Settings" and adjust the brightness of your screen. Push the button or buttons on the bottom front of the monitor to access the monitor controls. Scroll through the menus and look for a brightness control or contrast setting. Use the button or buttons on your monitor to adjust the brightness. Hope this helps
Jan 14, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I don't know how to turn down the brightness and contrast on the Acer monitor I recently purchased (Acer G205HL LCD Monitor). I tried the instructions and brought up the menu to make a selection by...
When you press menu on the monitor it will bring up the brightness & contrast, along with several other options. Navigate using the Up and Down keys on the monitor. Press menu on the monitor again to access the specific option you want to change and use the up and down keys on the monitor to change the option.
Jul 16, 2011 | Acer Computers & Internet
I have a dell crt monitor. Luminance Temperatura pop up on the screen and it go on and off. Sometimes contrast or bright appear on bottom of the luminance temperature. How do I fix?
Sep 01, 2010 | Dell E773C 17" CRT Monitor
Brightness contrast pop problem
one of the buttons will have dust in it causing it to trigger randomly or it is faulty take it apart and replace the buttons, make sure you do all otherwise it will still do it the work on impedence and they are all in series
May 28, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Can not access PC Brightness or PC Contrast - only X Contrast
From p.29 of the manual
"Brightness, Contrast, Sharpness, Color, and Tint are only available for adjustments
if you select User in Picture Mode.
Press / on the remote control or VOL+/ VOL- on the control panel to adjust these settings."
Apr 12, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
Acer monitor
hi, ya had solved this issue many times, the problem is with the switches on the monitor, you will have to clean it or replace it, sometimes a mild hot air blower on the control pannel also helps. but be careful not to over heat the screen, for all this you will have to open the monitor cover to access this switches.. let me know
Nov 22, 2007 | Acer AL1912B 19" LCD Monitor
Dell Dimension 4700 PC Desktop Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
