Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge xl44 stove digital display clock stop working.
My digital display does not show anymore. Nothing lights up on the display, but when you press any button you can hear it. What do you think I need to change? There is no problem with the stive or oven.
    Guru:
  • 310 Answers
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Posted on Sep 30, 2009
Hooking up a intellitrox tach on motorcycle but instructions only show for 4 6 8 cyls
Most Intellitrox Tachs will work on 1,2,4,6,8,10,and 12 cylinder engines. The mini-tach (MS9002) only works on 4,6 and 8 cylinders.
So if you have the mini-tach and do not have 4 or 6 or 8 cylinders, you should use a different tach. If you have a different unit, or have 4 cylinders, then see the second step below from their installation guide.
To change settings: (a light tap on the left button will engage the menu system: the right button will then be used to adjust each specific setting.) 1. Leftbuttonpressed:
Set # of digits in RPM display, using right button, display shows: (hundreds) 9900, (tens) 9990, and (ones) 9999.
2. Leftbuttonpressedagain:Set # of cylinders using right button, display shows: 01_C 02_C 04_C 06_C 08_C 10_C 12_C
3-A. Left button pressed again:
Set first digit on max RPM on gauge bar display (in thousands) using right button, display shows: 10__B to 99__B
3-B. Left button pressed again:
Set second digit max RPM on gauge bar display (in hundreds) using right button, display shows: 10__B to 99__B
4-A. Left button pressed again:Set RPM first digit shift light threshold (in thousands) using right button, display shows: 10_S to
90_S
4-B. Left button pressed again:Set RPM second digit shift light threshold (in hundreds) using right button, display shows: 19_S
to 99_S
5-A. Left button pressed again:Set first digit output switch RPM threshold (in thousands) using right button, display shows: 10_S
to 90_o
5-B. Left button pressed again:
Set second digit output switch RPN threshold (in hundreds) using right button, display shows: 19_S to 99_o
6. Left button pressed againWill return to normal mode, or if there is no new information to access, after 8 seconds, the
gauge automatically returns to normal mode.
When you have finished programming the settings, turn off the ignition to retain them in the gauge's memory. Next time you turn on the ignition, your new settings will be the default.
Nov 05, 2017 | Motorcycles
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
At the "battery empty" sign
long shot:
remove battery
press and hold down the power button,
insert battery
Jun 12, 2011 | Kyocera Finecam S4 Digital Camera
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
I hav the code ect (Blaupunkt 300 ina astra van), now need to know how to install / reset radio
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 21, 2011 | Blaupunkt Car Audio & Video
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
How to program a digital timer
You posted under a photo that looks like Woods 49063 or GE 28441
Link below shows this particular timer with manuals for each:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
If your timer does not show on link above, add a comment with as much description as you have, with button locations and color and purpose of timer.
To program the GE timer:
1) Set current time
Press and hold Time button: and then push hour and MIN button to set current hour and current minute.
2) To program:
Press and hold PROG button for 1 second
Prog 1 ON will display
This is program1 ON
Press hour button and MIN button to set program1 ON hour and minute
Prog 1 OFF will display
This is program1 OFF
Press hour button and MIN to set program1 OFF hour and minute
Prog 2 ON will display
This is program1 ON
Press hour button and MIN to set program1 ON hour and minute
Repeat steps to program up to 6 different ON-OFF programs
When programming is finished, press TIME button to return to current time.
3) Set MODE
Press mode button once and ON displays, this means light is ON
Press mode button again and OFF displays, this means light is OFF
Press mode button once and nothing displays, this means timer programs will run as you set them
Dec 12, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
How do i set the date and time on my canon p23 dh v calculator
If you want to set the time, the button that has a picture of the calendar and clock (just to the right of the arrow key) until it shows the time. Then press and hold the date/time set button (just tor the right of the red minus button) for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits and the am/pm button for am or pm. If you need to set the date, press the calendar/clock button again until it shows either the date or the time, and then hold the date/time set button down for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits.
Mar 17, 2010 | Canon P23-DH Calculator
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,193 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
