Question about SnapGear Computers & Internet
Snapgear SG580 Restarting
My snapgear SG580 has been restarting a couple of times a day lately. I can't find any good logs. How could I best troubleshoot this problem?
  • 32 Answers
SOURCE: Can we set up IPSEC
According to specs, it does support IPSEC. You'll have to go through the device's web config (usually 192.168.0.1 or 192.168.1.1) to change the settings.
Posted on Jan 08, 2009
  • 580 Answers
SOURCE: I have a 1996 chevy corsica , I have replaced all
Is your fuel pump working & if it is when did you change the fuel filter last? Did you move fuel line close to a heat source? I.E. exhaust manifold rad hoses etc. You could be experiencing vapour lock. Insolate fuel line with fuel line protecter material.
Posted on Sep 08, 2009
  • 159 Answers
SOURCE: the system is restarting at different times of the Day
Sounds like you need a BIOS update. Check with the motherboard manufacturer for an update.
Posted on Dec 09, 2009
  • 9 Answers
SOURCE: Difficulties in Restarting, log on, log off of
Reboot its better and safe it acts due to virus after reboot 1st instal anti-virus
Posted on Mar 02, 2011
  • 13 Answers
SOURCE: Every next day, while starting client computer
this problm of windows or hardware problm u checkout the any computer repaing center they solve tour problm
u change the powersupply , ram, tight karo processor or fan ko .
and change the window
Posted on Jun 08, 2011
I got error on ethernet. The Ethernet cannot connect or I can say that the Ethernet is down but the power is ON. H/B Led is also off. Can you help me?? thanks.
Please check your ethernet adapter's driver is proper instaaled or not.
you can also check your network device is working fine or not with connect to another laptop or desktop.
Mar 25, 2010 | Secure Computing SnapGear SG565...
Recently changed to new computer connected to Sg 300 now internet connection does not work
There has been a change in the “Operating Systems.” After the installing of the new software configurations in the system was change.
“The (SG) Firewall, is identifying the Internet Connection as being a “Security Risk,” this is why is being blocked!”
The Security Setting has to be changed. The best solution is to restore the settings back to “default” settings, now that the changes have been made.
To Start, go to the “Control Panel,” you want to open the “Internet Options” window.
Check the (Home Page), if your default search engine was changed, you can type it in example: (“Google”), click “Apply,” after each change.
Note: If you are not sure of the Home Page name, click on the “Default” block.
Next, you want to change the Security Settings; to make this a safe and easy process; rule of (“Thumb”) cannot go wrong with “Default” settings, click on each security zone, and click the “Reset all zones to default level.”To setup the Internet Connection: Click on the “Connections” block, click the “Setup” button, follow all the instruction carefully. Important! Always click apply, ok, and restart the computer after making changes to the computer. “Did this solution help?”
Jan 27, 2010 | SnapGear SG300 (990126) Firewall
I cannot log in because of this 81003002 problem.
There are a couple options to get rid of the problem:
1. Try restarting yahoo messenger
2. Try restarting your computer
3. Keep trying a couple more time
If this won't help, shut down the messenger and try again a bit later
Oct 02, 2009 | Yahoo Messenger
Default IP address after reset? SOHO+
If you have a PC hooked up to the router, check your IP on the PC by doing START > RUN, type cmd, hit OK, and type ipconfig /all and ENTER. Routers generally share the same first 3 numbers as the PCs connected to them and the last is .1. So if your PC IP is 192.168.0.23 the router should be 192.168.0.1.
It is usually 192.168.x.x in any case.
Jul 15, 2009 | SnapGear SOHO+ (990027) Router
I am trying to set up an IPSec tunnel to a service provider using a SnapGear SG560 (the product identifier below doesn't list the SG560, so I've selected the SG565, but it really is a 560, not sure if...
These rules look exactly the same to me. Service provider is saying provide an ACL - which is an Access Control List - which simply permits the traffic from the 172 class B to the two 192 class Cs.
As far as the second one, Service Provider is saying that anything GOING to 172 class B needs to be NATed on your inside.
Apr 02, 2009 | Secure Computing SnapGear SG565...
I need to make some changes in my Celestix FV940 configuration
Hi, Since this box just uses Checkpoint, There wont be much of complication in that. In box level you can take the help of CLI Help. For your ref. im giving the link of Manual.
http://www.allyourprices.com/product-specifications/10126220/Celestix-One-FV940-Security-Appliance.html
Mar 18, 2009 | Celestix Networks Celestix One FV940...
Can we set up IPSEC with SnapGear/SnapGearSME530 firewall ?
Jan 08, 2009 | SnapGear Snap Gear SME530 Firewall...
Flashing Lights
The flashing lights meen there is a configureation problem with your snapgear. Check your settings to make sure thay are current for your new location. Just because you own an IP/DNS from one service does not mean that it will be valid from another service. Some services use a system where you set your router to DHCP and they assign you your static IP/DNS. Also Snapgear routers have configurable ports so they are going to be picky about what is plugged into what port. Hope this helps
Jun 26, 2008 | SnapGear SME 550 (990065) Firewall
Computers & Internet Logo
66 people viewed this question
Top SnapGear Computers & Internet Experts
David Payne
David Payne
Are you a SnapGear Computer and Internet Expert? Answer questions, earn points and help others
