Question about Canon Rebel XT / EOS 350D Digital Camera
Canon rebel XT will not power up
I brought my camera in for a cleaning to discover that the lose CF button that I never had repaired might have caused a permanent power off situation. Can I fix it myself? The camera store told me to buy a new one camera. t When I left the store it was still working but not when I got home. So I bought a new battery to see if that was the problem, it still will not work.
SOURCE: No Power To Canon Digital Rebel XT
Yes, i got the same problem.
Posted on May 14, 2008
  • 153 Answers
SOURCE: Getting MESSAGE Err CF nd
Was your last picture no 9999?
if so reset the counter in the file numbering menu.
try a different card
use a torch to look down into the memory card slot to make sure there are no bent pins, beyond that its back to a canon service center I am sorry to say
Best of luck
Posted on Jun 15, 2008
Gryfox
  • 216 Answers
SOURCE: I am getting a ERR CF with my Rebel XT
You've probably gotten bent pins in the camera. Has to go to the shop.
Posted on Nov 27, 2008
  • 10 Answers
Change out the CR2016 3V battery. You have to remove the rechargeable battery to get to the CR2016. Refer to the manual for proper instructions.
Had the same issue with a two year old camera. This solved my problem.
Posted on Jan 01, 2009
t00nz
  • 4738 Answers
SOURCE: CANON REBEL XT -CF card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jul 02, 2009
Can not insert CF card into a canon rebel xt
Hi it is common problem of eos xt, xti.. you have a choice for repair your self or bring it to local repair shop. They would charge you around $50 to 215 depend on what they want to charge. (you also have check old cf card for future safety if you want to repair shop check.)
Jun 02, 2011 | Canon EOS Rebel XT Digital Camera
I believe this post will help you out..
Please CLICK HERE
May 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My camera canon eos rebel xt has an error code cf what does that mean ??? my camera doesn't since that code appeard.
CF probably relates to the Compact Flash memory card. It may be time for a new one. They're very inexpensive and a replacement would be the first step to discovering the problem.
Nov 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Aug 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel xt does not accept CF cards for no apparent reason
It sounds like a bent pin in the CF slot. This is not a do it yourself fix. Take it to a repair shop.
Jun 22, 2009 | Canon Rebel XT / EOS 350D Digital Camera
8 GB CF card has made the camera lose the Raw function even when I return old 1GB CF card still the same... any ideas?
1st, make sure the camera is in the Creative zone P, TV, AV, M or A-Dep. I have made this mistake many time and everytime I forget I moved the dial.
If dial is in the Creative Zone and still no RAW option then have the camera format the card, if that doesn't work do the following:
Turn off camera,
Remove lens,
Put on body cap.
Remove CF Card
Remove Battery
Let sit for about 30 minutes.
Put battery back in.
Put CF Card back in
Turn camera on
Put camera in Creative Zone
Push Menu button
Push Set button twice and check if RAW is now an option
If not then you can try the clear all settings function in the Set-Up 2 menu. Push the menu button then the left arrow button arrow down to the clear settings line push set the clear all functions.
If this doesn't help then I would say carry it to your nearest Canon Dealer that offers cleaning and service.
May 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT I can't put my CF card back into my camera. It goes almost all the way
Inside the slot is a broken or bending pins it must be changed or repaired.
Apr 30, 2009 | Canon Cameras
Xt rebel picture croping issue
Sounds like the shutter has gone faulty i'm afraid.
It looks like the camera will need to go to canon for repair
Mar 30, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problem with canon
Check the CF connector in the camera. One of the pins might be bent...
Dec 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nov 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
98 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
