Question about Kenwood VR-407 Receiver
I can't get the remote to work. Very intermittent at best. Remote is working.
  • 555 Answers
Sounds like the battery from the remote control needs to be replaced. Even if the equipment is new, the battery may be a few years old.
Posted on Sep 30, 2009
TOSHIBA 36AF42
Your Fios box seems to be faulty
Mar 29, 2008 | Toshiba 36AF42 36" TV
Dish tv 21.1 control solutions
craneserv710,
I would need more information on if it has intermittent control of TV or satellite to provide the best information. I have listed some steps to try below for either situation!
Satellite:
If the remote has intermittent use on the satellite, ensure there is nothing that may be causing interference. For a TV1, this could be a fluorescent light, or a direct heat source blocking the IR signal. If it is a TV2, interference may be caused by a device that is powered on. You can try turning off equipment to see if interference is removed, or you can try moving the antenna on the back of the receiver. If it is sticking straight up, turn it parallel with the receiver. If it is laying flat, put it straight up.
Television:
If the intermittent control is for the TV functions, you may need to program a new code into the remote. There are multiple codes for a remote and some will work completely, while others only provide intermittent functions.
Let me know if you have any other questions, or if you can provide additional details! I'll be happy to assist you.
Tommy Faust
DISH Social Media Representative
Apr 12, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
My wife and I have the same type remote. Hers works well and mine has for the past six months decided to work when it wants, no matter how many times or however long you hold the button down it fails to...
1. Change the battery in your remote 2. Are you using you remote in the same way as your wifes, ie on the cars sun visor, try putting both remotes in the same location and activate the garage door with both remotes several times if yours fails your remote has an intermittent fault.
Dec 28, 2010 | liftmaster 373lm Liftmaster Craftsman...
I have a Liftmaster garage door opener & remote. The remote began to work only intermittently. I replaced the battery (I didn't reprogram remote when battery was changed & remote worked for a...
COULD BE A BAD REMOTE, I WOULD TRY ANOTHER ONE FIRST.
COULD BE A FREEZER ETC. PUTTING OUT INTERFERENCE.
OR
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Nov 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Remote for Sony vcr works intermittently.
Sounds like the connections inside the remote are damaged and might need soldering. Check the connections around where the battery terminals are carefully. Has a battery leaked in the remote?
Jan 28, 2010 | Sony SLV-N500 VHS VCR
Search forward button (>>) on DMR-E65 remote inoperational
Carefully pry the remote apart (check for screws). Then you can take a q-tip and some alcohol or Windex and clean any dirt or contamination from the circuit board and the bottom of the button pad. You can some times see rings on the board where the buttons make contact and that is what needs cleaned off.
Sep 07, 2009 | Panasonic DMR-E65 DVD Recorder
Bryston amp b100 sst intermittent remote volume control problem
Without going to Bryston for a new remote, I would take the batteries out of the remote and soak the remote( slosh it around too) in a zip-lock type bag with pure isopropyl alcohol for a couple hours.
Let it dry. Try volume again
Mar 31, 2009 | Bryston B-100 SST Amplifier
Insignia 32" remote does not work
If you have a cell phone with a camera on it, aim the remote at the camera and look at the screen on your phone. Press a button on the remote, and see if you can see the light blinking on the remote, on the cell phone screen. If you can, at least you know the remote's working.
If it is, check to see that there is nothing blocking the line-of-sight to the screen.
Finally, when all else fails, try a cheap universal remote. Go through the manual programming steps.
After that, the only solution is a faulty IR sensor in the unit itself. Bring it in to a repair depot....you should probably still be under warranty.
Jan 01, 2009 | Insignia IS-LCDTV32 32 in. Television
Remote problem
It sounds like an intermittant Infared sensor problem or there is an intermittant solder connection between the sensor and the controler chip. Good Luck
Apr 08, 2007 | Kenwood VR-407 Receiver
Kenwood VR-407 Receiver Logo
35 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
