Question about Panasonic PT-AE500U Multimedia Projector
I have a Panasonic PT-AE500U projector i am on my 4th bulb now and i have a blue hue on the left side. It was on both sides, i had it sent in and cleaned and now theres only a hue on the left side. I have taken it apart myself wearing latex gloves cleaned the lenes and i got rid of the little blue spots but not the blue hue on the left side of the screen? What would that problem be. Thank you
    Brigadier General:
  • 4,090 Answers
Optical block is the culprit! replacement is not too difficult. About the only special tool required is a long phillips screwdriver to reach the screws securing the block to the front panel of the set. Then, there are three connectors on the C board which is part of the block, one connector on the left side of the C board, one fan connector on the left side and then two connectors on the lamp driver board which is on the back of the optical block. Two recessed screws hold the block to the front panel and sometimes there is a third recessed screw to the left of where the lamp is located. Then the block slides out. Reverse the procedure to install the block.
Thanks for using FIXYA
Posted on Nov 27, 2009
MY PT-AE700U LCD PROJECTOR HAS A BLUE HAZE RUNNING VERTICALLY ON THE LEFT HALF OF THE PICTURE.
Open the upper cover remove screw back side of the projector
Remove LCD connector and clean with soft cloth and fix it again.
close the upper cover and then POWER ON if the problem exist then the blue LCD is faulty and need to be replaced.
(very carefully because the ribbon cables and connector of the LCD is very senstive)
Jan 22, 2011 | Panasonic PT-AE900U Multimedia Projector
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
I replaced the lamp on a Panasonic PT-LC80U thinking this will solve the yellow appereance, but it did work, it seems that there are not blues in the image. What Can I Do to solve the problem?
here are some probable causes..
This appears to be an older model (over 5 years old) and LCD projectors turn yellow with age. It's just what they do
However, if you are projecting a computer signal or a component signal, a short in the blue signal of the cable can cast yellow hues over your image. The hue will cover the entire image as if you are viewing the image "through rose (or in this case, lemon) colored glasses" so to speak. That's an easy fix.
Harder fixes: the blue LCD panel is weaking and/or gone bad.
If you have a round yellowish spot in the middle of your screen, the diffuser has been overheated and is "burnt".
Apr 08, 2010 | Panasonic PT-LC80U Multimedia Projector
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
Projector picture cuts out for a few seconds then comes back on.
Dear,
Your projector problem on cooler is not run properly,so it goes to shutdown.Clean every surface from blowing through.Then all dust clean.
Dec 26, 2009 | Panasonic PT-AE500U Multimedia Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
Panasonic PT-52LCX15- Have a Blue hue along bottom and on part of screen, replaced bulb 2 times, same and used a philips and now panasonic bulb and housings. Any suggestions? Projector? Time to call...
This is a 2005 model; it sounds like you have a burnt optical light engine: part number is
TZSC03047 Part is about 800 dollars and requires tech approval from Panasonic to buy. A number of these optical engines use an elaborate system of lens---the heat from the lamp can damage the lens and the color that is damaged separates enough inside to cause the blue streak somewhere on the screen. I hope you have an extended warranty on this set.
I do this here for free so if this has helped you give me a vote here.
Aug 27, 2009 | Televison & Video
PT-L735 U projectors. Green screen and stretched
The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
good luck
Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
199 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
