Question about Compaq iPAQ H3850 Pocket PC
I can't make my IPAQ pass the align screen
I forgot to charge my Ipaq Pocket PC (It's an old model from 2002) and it run out of battery. Now every time I try to turn it on it stays on that red screen that says "align screen". I reset it several times but it doesn't work.
Do you have any idea what's wrong??
Thanks
  • 1 more comment
  • Anonymous Feb 13, 2008
    the same exact problem..hw to fix it..??!
  • Anonymous May 15, 2008
    i have same problem ifdo you have any thing send me message thaks
  • scarebear777 Aug 22, 2008
    get out of alligh
    tap screen twice in top right corner quik
    scarebear
Use Active Sync, explorer the folder contents on the device, move to the windows folder, delete the file welcome.exe. Soft reset and should work.
Sometimes you have to end all Active Sync tasks, rapimgr.exe, wescomm.exe and WCESmgr.exe. After you close all these, reopen Active Sync, should then be abel to connect your device and try again.
-m0gliE
Posted on Feb 27, 2008
Yo people tap screen twice!!! in top right corner
scarebear
Posted on Aug 22, 2008
    tap the screen twice very quik in top right corner
    scarebear
Stuck on "align screen" How I align screen H6300 Ipaq
hi friend...
try an HARD format,,,that will solve it sure.....
thank u ../////
PLEASE RATE IT
Nov 11, 2009 | HP iPAQ H6300 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Compaq iPAQ H3800 Pocket PC
I had the same problem with my iPAQ H3800. I bought a replacement battery on eBay for £7.49 and now it's fine.
Dec 11, 2008 | Compaq iPAQ H3850 Pocket PC
Pass the align screen
Hey :), id be happy to help. You see, I too have a Ipaq except I had Ipaq 4350. Now, I too had the same problem you are having. The reason why you can't pass the align screen step is because somehow you have damaged your screen. And I have come to the conclusion that HP Ipaq's screen is extremely sensitive, ( because I never did anything that bad to my screen for it to be damaged) soo I'd recommend for you to call HP and see if they can repair your problem or give you another one. Thank you and I hope this helps!
Sep 03, 2008 | HP iPAQ H2210 Pocket PC
Ipaq
Do a hard reset - note it will remove all your data.
If a hardreset doesn't fix the problem then you either have a faulty touchscreen or other fault in it and you have to send it in for serivce contact HP.
Jun 28, 2008 | HP iPAQ RX1710 Pocket PC
Mirrored image IPAQ 3650
Could you write down the part number for the old and new screens to check for compatibility?
Regards,
May 24, 2008 | Compaq iPAQ H3650 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
Compaq iPAQ H3850 Pocket PC Logo
537 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
