Question about Standard Horizon Magnum Nav-40 GPS Receiver
Where do you get your updates - Standard Horizon Magnum Nav-40 GPS Receiver
How to update browser on a icebox ct04
It appears that icebox has gone out of business. The ct04 is supposed to automatically update every night at 2am on whichever day you first activated it. You can also do this manually, and I put directions how to at the end, but if they are closed the servers that these updates come from are probably no longer working. There is a third way of updating. Their manual states that some updates were issued on CDs. So you might be able to find one of the later updates this way, keeping in mind that they almost certainly won't be very current.
To manually update.
1. In internet mode, press options and select internet options.
2. From the internet options menu, select Updates.
3. Choose the Check For Updates button.
4. After it checks for updates choose the Update Now Button. It will then download and install the update. After it restarts you will see a Update Complete message. Click OK.
To update by CD.
1. Insert the Update disc.
2. The system will display update information. Choose the Update Now button.
3. When finished it will display the Update Complete message, choose OK.
Good luck.
May 28, 2014 | Dell Dimension 2400 PC Desktop
Windows is more up to date than th one tryng to download,I need to cancel this but do not know how to find it
. First of all click the Start button to view the Start Menu. Then choose the Control Panel option.
2. The Control Panel window opens up now.
Click the System and Security link from the Control Panel window.
Important updates provide significant benefits, such as improved security and reliability. Recommended updates can address non-critical problems and help enhance your computing experience. Optional updates are not downloaded or installed automatically.
6. Important Updates can be configured in four ways:
  • Install updates automatically (recommended)
  • Download updates but let me choose whether to install them
  • Check for updates but let me choose whether to download and install them
  • Never check for updates (not recommended)
If you choose Install updates automatically , there are additional options to schedule the update at a convenient time.
3. The System and Security section of Control Panel opens up. Here you can see the Windows Update link.
As you can see in the above screenshot there is direct links to the important Windows Update option here it self in slightly small fonts, such as Turn automatic updating on or off, Check for updates, View install updates . You may choose the required option directly from here. But we are going ahead to the dedicated Windows Updates section of the Windows 7 control panel by clicking the main Windows update link.
4. So now we are at the Windows Update section of our Window 7 Control panel. You can manually look up for any new updates by clicking the Check for updates button under the heading Check for updates for your computer fromthis window. In order to modify the Windows update option click theChange settings in the left pane.
5. Here you may change the way Windows 7 download and install updates. Configurable option include Important Updates , Recommended updates ,Who can install updates and Featured update notifications .
or if Never check for updates is selected:
Oct 05, 2013 | Microsoft Windows 7 Ultimate 32 bit Full...
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
Jun 16, 2011 | Nokia N73 Cellular Phone
How to update windows xp
Go to Microsoft Update and follow the appropriate instructions.
Jun 11, 2011 | LG Computers & Internet
How can i update my Microsoft office?
Easiest way to update i.e. if you do not know which updates to select. Before you update your system or applications, through Microsoft update Microsoft will validate if your softwares are Genuine!!
Use the microsoft update, to update your OS as well as your microsoft office too. If you just wish to update your microsoft office you have to select "custom" update at the microsoft update site and check the updates you want to update your microsoft office 2007.
Hope it helps.
Aug 26, 2010 | Microsoft Office Word 2007 Upgrade:...
Update for sony psp 2000 ver. 3.71 m33-2
visit the website us.playstation.com/psp/About/SystemUpdate/pc.html
May 06, 2008 | Sony PlayStation Portable (PSP) Console
Windows xp updates
Download from this link service pack 3
Mar 31, 2008 | Computers & Internet
Updating PS3 .PUP file
Update data download procedure
  1. Create a folder on the storage media in which to save the update data.
    Using a PC, create a folder named “PS3” on the storage media or USB device. Within the PS3 folder, create a folder named “UPDATE”.
  2. Download the update data and save it in the UPDATE folder created in step 1.
Notice Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3™ system will not recognize the update data. The folder name must be in all uppercase letters.
  • File name: Save as file name “PS3UPDAT.PUP”.
Update procedure Notices
  • Do not turn off the PS3™ system or remove the storage media or USB device during an update. If an update is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • The power button on the PS3™ system front is not active during an update.
  1. Insert the storage media or USB device that contains the update data in the PS3™ system.
  2. From the home menu, select icn_settings.gif (Settings) > icn_ntwkupdate.gif (System Update), and then press the x_button.gif button.
  3. Select [Update via Storage Media], and then press the x_button.gif button.
    The system automatically searches for and finds the update data saved on the storage media or USB device.
  4. Start the update data.
    Press the x_button.gif button to start the update data. Follow the on-screen instructions to complete the update.
  5. Confirm that the update was successful.
    After the update has been completed, go to icn_settings.gif (Settings) > icn_ps3_systemsettings.gif (System Settings) > [System Information]. If the System Software field displays the version number of the update, the update was successful.
Hint
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Standard Horizon Magnum Nav-40 GPS Receiver Logo
24 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
