Question about JVC Televison & Video
JVC (CRT) TV AV38M501. Worked earlier today. Now won't turn on. Red power light is on. Will not respond to buttons
  • quinmartin Sep 30, 2009
    It did have surge of power when I plugged it in after moving it from another location. Old TV set and very heavy. Hernia type!!. Doesn't sound like it's work fixing. Time to buy a plasma?
    Thanks for the feedback.
    Seems like it might not be worth fixing. Too heavy and bulky anyway. Time to buy a new plasma. Thanks for the assistance.
  • 555 Answers
There are two possible causes of this:
First: Usually this problem is caused by spikes or issues with the power (electrical grid). I have seen this on other brands. Usually the power supply is broken and needs repairs.
Second: An integrated circuit overheated and it's now damaged OR the heat caused a loose connection (perhaps a dry joint).
Unplugging the TV and waiting about 20 minutes may help (if you are really lucky) but I don't think it will do anything.
II recommend you to check the user manual to verify if the TV still under warranty so you can get assistance from the manufacturer about repairs.
Good luck.
Posted on Sep 30, 2009
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I need to get code for tv
Hello
Three Digit universal remote codes for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Four Digit universal remote code for JVC are:-
0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 30, 2010 | JVC AV-27530 27" TV
Possible power surge earlier today. TV will not
If your TV was plugged into a power strip with a surge arrestor, the power strip may need a reset (if there is a reset button) or replacement (those surge arrestors are only good for so many "hits". Try plugging the TV in elsewhere.
If it was not plugged into a surge suppressor, it is time to call a repairman.
Oct 07, 2009 | JVC AV-20220 TV
Can't turn TV on with remote or with Power On button on the TV
the problem can be the flyback transformer or surrounding component. check if you how to do that . If you don't know don't do that because it is very dangerous.
Sep 23, 2009 | JVC AV-32120 32" TV
JVC TV Sleeping
Indicates a power supply failure, needs a few filters replaced expect to pay $100-150 Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | JVC AV-27320 27" TV
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
JVC AV-32870 Power button is missing
I had a friend that had the exact same problem! We did use a remote to turn the tv on and then it was a matter of setting up the menu settings. It was trial and error, but it was worth it. As far as getting the power button replaced, I would recommend call and ask a TV repair person - but the remote worked just fine for my friend.
Jan 06, 2009 | JVC AV-32820 32" TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
Power button flashing, will not turn on or off
Electrolytic cap in low voltage supply
Apr 23, 2008 | JVC AV-32260 32" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
