Which line do I connect to to recharge my a/c in my 97 mercury tracer
  • 71 Answers
Connect to the low side....being a 97 it should already have the R 134a in it.....when you get the kit to recharge it, it comes with the fittings and the fittings will only let you charge from the low side.
Posted on Sep 30, 2009
Where is the vin located on 97 mercury tracer?
at the base of the windshield on the drivers side. On the build sticker attached to the opening of the drivers front door.
Oct 08, 2016 | 1997 Mercury Tracer
97 mercury tracer hold pettle down to start wont stay running
if when holding down the pedal the motor runs like a tractor your motor needs rebuilt
Mar 11, 2012 | 1997 Mercury Tracer
Where do i put transmission fluid in my 97 mercury tracer???????
U NEED A FUNNEL IT GOES IN THE SAME PLACE AS THE DIPSTICK YOU USE TO CHECK THE FLUID
Dec 12, 2010 | 1997 Mercury Tracer
I have a 97 Mercury Tracer with disk brakes in rear. I disconnected the emergency brake cable and loosened the bleed screw and cannot compress the cylinder to put new pads on. Is there a trick?
take a pair of channel locks and turn the caliper piston clockwise while pushing it in a little bit at a time until it is in all the way. Some pins on the back of them so they sit in the caliper right. make sure to line those pins up. They do make a tool to turn the piston but I have done it this way before. Hope this helps leave comment.
Jun 27, 2010 | 1997 Mercury Tracer
I have a 97 mercury tracer that quit on me going down the highway, there were no warning signs it just died. It would crank but not turn over even when we tried to jump it off. We towed it in and the...
BATTERY MUST READ 12 VOLTS AND 11 VOLTS ON A DRAW OR WITH A LOAD ON IT
IF YOUR ALTERNATOR STOPS WORKING THEN THE BATTERY WILL GO DEAD AS THE ENGINE HAS TO HAVE ELECTRIC TO RUN ( WHEN YOU CAR REACHES 8 VOLTS THE COMPUTER WILL SHUT OFF EVERYTHING TO SAVE IT'S SELF FROM BURNING UP SO CHECK YOUR ALTERNATOR AND RECHARGE THE BATTERY
Mar 02, 2010 | 1997 Mercury Tracer
My radiator fan won't turn off on a 97 mercury Tracer.
its probably a stuck relay locate it and replace it with another most likely that will cure it. check under the hood for a relay center.it should be diagrammed on the lid and use 1 from a different position first pull the one for the cooling fan if it stops that should cure it
Jul 18, 2009 | 1997 Mercury Tracer
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
