Question about Epson Stylus Photo R300 InkJet Printer
Any way to by pass "out of ink" and print just with black?
  • Epson Master
  • 419 Answers
No... sadly not... The printer protects itself from damage by now allowing nozzles to fire when they are empty of ink.
Many folks think that a particular colour is not being used when it's not obvious in the printout but as a general rule, almost all colours are being used at some point in any printout so the printer stops when a cartridge is empty.
It's a pain but a necessary evil I'm afraid...
Posted on Sep 30, 2009
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | HP Photosmart C6100 All-In-One Printer
Only prints other colors except black. Have change the toner but problem still exist.
Hi if you have put a new black ink in your machine and it still will not print black you will need to do a print head clean. you will find this on you pc in printer properties.
The problem is the ink can dry up and set in the print head so no new ink can get passed.
in the cleaning fails then you will need a new print head this is a part that you can if and if you go to Amazon and look for PIXMA iP3500 print head you will find it at about £45 ish
Yours Ian
Mar 17, 2011 | Canon PIXMA iP3500 Printer
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
I have inserted new black ink. but it is not printing in black. color ink is not new but color is printing but without quality. hpofficejet 5610
Hi
check expire date on black cartridge if it has pass
replace it with a new one or remove all old ink and replace it
with fresh one ..check here how
Oct 12, 2010 | HP Officejet 5610 All-In-One InkJet...
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Black wont print
THE BLACK INK CART. either dried or end , make a test , take out the cartridge and get a piece of paper towel and pass it gently
where the ink is .hope this helpful AJ
May 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My black ink will not print. If I change the colour, it prints find. It is a new cartridge.
First you need to ensure that this is not a driver problem, by reinstalling drivers and testing the printer on a different computer.
Also ensure that ink cartridges are OK, try replacement inks.
If the problem is not a software problem, and the printer is recognised by computer, and the printout is coming as a blank or faded page, then you usually have a faulty or clogged printhead.
Try first performing print head cleaning procedure from printer tools, that may not fix the problem, but do the cleaning a couple of times, just in case.
If the print head is clogged, that can be fixed soaking the print head in isopropyl alcohol overnight.
If still no luck, then the printhead must be replaced, here is the part: Canon MULTI-PASS F-80 Print Head $61.00
Apr 26, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Printer= Epson stylus Photo R200=will not print in black
The printer is designed so that you have to have ink in all the ink cartridges. They sell more ink this way. I have the same printer and investigated this a few years ago. there is no work around. Peter
Jan 10, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
