1994 Mazda MX-3 Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What oil type does my car take? its a mazda mx3
Im just wondering what kind of oil my 1994 mazda mx3 takes? also how much?
Anonymous
Level 2:
Scholar:
  • Expert 122 Answers
  • Posted on Sep 30, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
122
Questions
0
Helped
60495
Points
402
On the 1.3L 4 cyl 3.5 quarts 5W-30 1.8 L 6 cyl 3.5 quarts 5W-30
Anonymous
Level 2:
  • Expert 301 Answers
Anonymous
Expert
Level 2:
Answers
301
Questions
0
Helped
174967
Points
959
If I remember right it uses 5w30. Not sure as to the amount, but somewhere around 4 quarts plus or minus.
Mazda 1994 MX3 fuel cut off
What is the question here?
I was wondering how do I add transmission fluid to my 1992 Mazda mx3
Automatic I pressume ! You will have a job filling transmission fluid , as oil filler is on top of transmission , and needs to be filled while on a ramp , somtime special tool need to open filley
1994 mazda mx3 starts and then quits
Blue smoke from the exhaust = burning engine oil.
2answers
Hi im have trouble with my idle,i have a 94 mazda mx3 and it flucuates when i push the clucth in to slow down and when coming to a dead stop then drops real low and wants to stall out. i replaced idle air...
Timing out by a little bit? Not a rotary is it ,cam belt or chain dont know what mx3 has being a tooth off correct position caused by tensioner ?or a sensor crank or cam ,needs pluging in to a reader or if its early ecu may flash led with fault code.hard when cars on other side of world
I got 1993 mazda mx3 i changed cv joints and my gear oil leaked out of tranny.. i cant figure where or how to refill
there should be a square divet one low and one high on the side of the transmission that you can unscrew and refill with the gear oil.
1helpful
2answers
Mazda mx3 clicking when cold
This is because the oil hasn't circulated in the HLA (hydrolic lash adjusters) that is ontop of the valves/springs under the cam. Once they are full with oil, the clicking stops and they opperate properly! Try running a thicker oil, other than that it's not a big problem unless the ticking is very loud or doesn't stop after it's warm.
My mazda wont turn over i cant find the cylonoid or the starter
check oil ?check your battery cables clean them.and the car ground cables.
3helpful
Free download for manual
http://www.mx-3.com/manuals/index.php?folder=/1992%20Workshop%20Manual/
2answers
1994 mx3 1.6L DOHC ticking at the top of the engine. could the cam's be wore out or an oil gallery plugged. nay suggetions.
had the same problem and my oil level was low..... filled it up and havent had a problem since....
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
