Question about Sony Cyber-shot W290 Digital Camera
How to partial color sony w290 camera
What is and how do I use the partial color feature, on a sony w290 camera?
3 Suggested Answers
SOURCE: How to change date and
Turn on the camera
select a setting item with up or down arrow
select date and time format
select daylight savings
then set date & time
Posted on Aug 30, 2010
  • 51 Answers
SOURCE: my sony camera DSC-W290 has
according to sony support you should try first to reset your camera to the default factory settings. You can find the article here:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
and here is the manual for your camera:
http://www.docs.sony.com/reflib/docget.asp?manualid=1031952&template_id=1®ion_id=1
If you look into page 131 of the manual you can find your problem, and on page 85 is described the reset procedure: you should go to menu/settings/main settings/initialize/ then OK
Let me know if this helped you. Bye
Posted on May 04, 2011
Bright
Almost all cameras have a color and white balance settings. Try messing with the white balance first and lowering it. I'm not familiar with your specific camera, but I have one that has a reset function under the settings menu. It allows me to reset all settings to default, that might work.
Apr 28, 2013 | Sony Cyber shot DSC W290 12.1 MP Digital...
SonyManual for Cybershot DSC-W290
Go to setting then select date & then time change then and save the settintg.
Aug 08, 2012 | Sony Cameras
My sony camera DSC-W290 has an error message E:91:01 error message flashing and flash don't work
May 04, 2011 | Sony Cyber-shot W290 Digital Camera
I have sony DSC-W290 Cybershot Digital camera. it has zoom of 5x. currently, zoom is working up to 1.4x.After 1.4x the more zoom i did the photo is showing blur(Not clear).
I would check and confirm that you are zooming using the optical zoom. It sounds like you may be zooming using the digital zoom, which would have this effect.
Feb 28, 2011 | Sony Cyber-shot W290 Digital Camera
C:32:01 system error , appears on My Sony Cyber-shot W290
"C:32:01 System Error" means, there's something wrong with the memory. Attach it to your computer and format the the card as 'FAT'. Formatting as 'FAT32' or 'NTFS' will produce this error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 21, 2011 | Sony Cyber-shot W290 Digital Camera
The lens of my sony camera will NOT retracked. What can I do, I love this camera.
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Dec 18, 2010 | Sony Cyber-shot W290 Digital Camera
Recently purchased the Sony DSC-W290 and I have
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Apr 08, 2010 | Sony Cyber-shot W290 Digital Camera
Sony Cyber-shot W290 Digital Camera Logo
195 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
