Question about Video Game Consoles & Games
After about 20 mins of playing my kit just stops working and all the red LED's flash. Im assuming its losing its wireless connection and i am unable to re sync it unless i remove the batteries, but even then it will only last a couple of minutes before it does it again
  • 943 Answers
I suggest your batteries are weak.why dont you try calling sony and explaining this to them.
Posted on Mar 12, 2010
My R2D2 interactive juste flash red
hola tengo el mismo problema que tu, cual es la solucion?
Te escribo desde Spain, mi correo jmbiedma71@gmail.com
gracias
Nov 15, 2012 | Hasbro Star Wars R2 D2 Interactive...
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
May 16, 2011 | Belkin Mini Wireless Optical Mouse...
Im just setting up my 2wire 2701 it works for a few secounds then stops the dsl light is flashing red. Any thoughts?
Hey!
The way I see it, there are 2 options:
1) There's a problem with your phisical internet connection - check the modem configuration and\or contact your ISP so they'll check that everything is configured well on their side.
2) Your router is failing... have it replaced!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Jan 08, 2011 | Gateway Wireless-B Router (wbr-100)
Buzz wireless buzzers
i tried several times to fix the problem by syncing the buzzers. it never solved the problem. finally i removed the dongle and blew on it very hard. i plugged it back in and retried. THIS ACTUALLY WORKED. i have played several times with no problem.
hope this is helpful.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
XBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Jun 30, 2008 | Microsoft Xbox 360 Wireless Controller
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Power and led on but yet no sound
red means protect, check speakers first then disconnect all power,try again in 20 min
Aug 22, 2007 | Visonik V900XD Car Audio Amplifier
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
