Question about Sewing Machines
I need to know how to thread my Pfaff 1200 - Sewing Machines
    President:
  • 1,462 Answers
Beginning with the spool, guide the thread through the thread guides to the tension assembly.
Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it passes this test, continue up through the take up lever,then down through the thread guides to the needle.
Make sure your needle is fully inserted and turned the correct way.
And moreover you can get the manual downloaded from the below site by paying some small amount
http://ifixmachines.com/Pfaff-Sewing-Machines-Manuals-and-Parts/View-all-products.html
This manual gives you a pictorial representation of threading
Please leave comment, if you need futher assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
How do I thread hobby grand quilter 1200
The Hobby 1200 is a Pfaff sewing machine that they call the Grand Quilter. First raise the presser foot and make sure that the needle is at the highest position (press the needle up/down button twice with the machine on). Then turn off the machine and unplug it for the maximum safety. For the top thread, place a spool on the spool pin and guide the thread through one of the two thread guides on the thread guide bar. The thread starts from behind the guide. (The post holding the guide bar is next to the spool pin.) As with most sewing machines, you will work from right to left and lead the thread down then up before going down to the needle. Bring the thread to the next thread guide (in front of the bobbin winding pin) and pass it through one of the holes from the back. Wrap the thread to the back of the guide and then through another of the holes. If the thread tension is very loose, try going through all three holes. Bring the thread down between the pre-tension discs going counter-clockwise.
Hold the thread in both hands and guide it around down and around the tension dial from right to left. Bring the thread up to get it between the tension discs and behind the tail of the check spring. Bring the thread back down over the loop of the check spring then under the thread guide that looks like an upside down L with a curve in it. Bring the thread up and through the next thread guide. (This guide is horizontal and just above the previous guide and one side ends near the center of the tension dial.)
Bring the thread up and pass it through the eye in the thread take-up lever and then back down through the horizontal thread guide above. Slip the thread into the thread guide and then down to the needle bar thread guide. Thread the needle from front to back. The thread should be along the groove in the needle.
You can find the manual at Pfaff's Machine Update page: http://www.pfaff.com/en-US/Support-and-Updates/Support . Search for the model and then you'll get to the product page: http://www.pfaff.com/en-US/Support/3336 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/GrandQuilter-manual-EN.pdf . The threading section starts on page 21 (page 23 of the PDF). The manual has good pictures that are better than my attempts to describe the guides.
I hope this helps.
Apr 28, 2018 | Sewing Machines
My Pfaff hobby 1200 keeps breaking the thread while free motion quilting.
I'd try switching the needle type & size and then a different brand of thread.
5 things you need to know about thread when free motion quilting
Machine Quilting Thread Shreds Then Breaks
Thread Top Thread Breaking Shredding while free motion quilting NEED HELP
Thread breaking or fraying when free motion stippling
Oh, yeh, one more thing I just thought of: Rethread the top thread and make sure the thread is not hanging up on the spool, spool pin, or wrapped around a thread guide. When my thread breaks after 3-4 inches, it's usually because something is stopping the top thread.
Jan 14, 2018 | PfaFF Sewing Machines
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
How to thread a pfaff 1200 grand quilter sewing machine
contact Pfaff website about a manual or try youtube for a video
Aug 25, 2014 | PfaFF Sewing Machines
Pfaff 1200 top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 03, 2013 | PfaFF Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
