Question about Linksys WRT160N Wireless Router
A really bizarre problem with WRT-160N. I have the Network Connection Status open and the connection speed cycles thru from 130 Mbps down to 1.0 Mbps within about a minute. It keeps doing it! I have never seen a router behave this way. I have the latest firmware available.
  • 496 Answers
I had that happen with my wrt54g it would go from 54 to 1 and start over again well i learned my leason there i tryed reverting to the original firmware and ended up toasting my router so dont try that :) im not to sure what the cause of this is either i do think that it in the router and not the wifi card tho
Posted on Oct 01, 2009
  • Linksys Master
  • 2,263 Answers
Try to change the wireless channel on the router.
WRT160N router has the issue with the Firmware.
You can upgrade the firmware of the router.
That will fix the problem.
Once you upgrade the firmware of the router, it will work properly.
After upgrading the firmware , reset the router for 30 seconds and reconfigure the router.
Click here for more info about routers
Posted on Oct 31, 2009
Network Print speed is slower then direct USB connection
Not a surprise because USB 2.0 standard is common these days and operates at up to 480 mbps. Your network connection is 100MB if wired and potentially 11 mbps if older Wi-FI or 54mbps if a little newer. The advantage is distance - wired up to 330 feet and wireless depends on a lot of factors. USB is really intended to work at 10 feet or less. Other factors can limit network speed dramatically like the switch or wiring and errors.
Feb 26, 2018 | Office Equipment & Supplies
While watching the movies are interuppeted constantly with a red circle showing reloading really sick of it cant watch a movie
What is the bandwidth speed of the connection to the device you are watching the movie on. Is it via Wi Fi 802.11N as it will not be fast enough. What is the ISP speed is it ADSL Modem (speed could be a problem depending on distance from Telephone Exchange) or Cable Modem. Try temporarily connecting directly via a Cat5E ethernet cable directly into your Network Hub and see if it improves. If wireless 802.11N you may want to consider 802.11ac which runs faster (if you can use a USB network adapter for 802,11AC ) if ISP speed is at least 433 Mbps and you have 1000 mbps network switch and network connection ethernet hub out of ADSL or Cable modem is 433 mbps or 1000 Mbps . I am going to connect a power point network adapter as the newer technology runs over power points a lot faster than my previous 85 Mbbps device. I could not watch Netflix moviesd as 85 mbbps was not fast enough and trying to use Adobe web conferencing via my 802.11N Wi fi or the 85 mbbp power point device is not fast enough.
Sep 01, 2014 | Computers & Internet
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work...
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
I just installed d-link wbr-1310. I am getting 1/4 the speed using wireless. Are there any setting I change to resolve this.
Wireless connections are running on a slower speed by definition.
A wired connection with this router sets the maximum speed at 100 Mbps.
A wireless signal in a 802.11b network has a maximum speed of 11 Mbps, and a 802.11g network has a maximum speed of 54 Mbps.
These numbers are theoretical numbers and never achieved in reality. (like a Toyota Prius makes 60mpg...)
So depending on your wireless network adapter and how your setup physically looks like (distance to the router, interference with telephones, microwaves etc.) it is absolutely possible that you wireless speed is considerably slower than your wired connection.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 20, 2009 | Computers & Internet
Wireless internet connection
Hi there I would tell you why:
1) your DSL speed band only 1.5M and the upload could be lower then 256K speed. that is not avalible to get good condition for more laptop wireless online at same time
2) other thing, your laptop wieless online in your router situation that depends on the laptop wireless card type, high level (faster)card will get more speed band and aganst other laptop.
so you could not setting any more to get improved.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 28, 2009 | Sony VAIO VGN-FW235J Notebook
SPEEDTEST.NET RESULTS VERY POOR AND VARIABLE THRU ROUTER
First what type use router and you using internet firewall ya VPN
plz tell me
Mar 14, 2009 | Dynex 4-Port Ethernet Broadband Router
Linksys WRT160N Wireless Router  Logo
376 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
