Question about Nokia 1600 Cellular Phone
Nokia 1600-no power
I replace my empty batterry in nokia 1600.but i cannot switch it on
This s ma imei no:356812029244892.. pls give me a reset code
Hi There
You mobile unlock code is mention below as you IMEI number, if you are not success then try the below instruction to unlock mobile.
IMEI Number
356812029244892
Unlock Code:
7462056640
Warning : Do not enter any wrong unlock codes on your Nokia 1600 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1600 mobile phone, your phone may get permanently locked and sometimes become unusable.
1 - Switch on your Nokia 1600 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1600.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1600 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1600 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1600
Thanks
Prashant
Nov 29, 2011 | Nokia 1209 Cell Phone
The security code that u gave to me is not working pls give me the ryt answer to my problem tnx...
Hello Jenni,
To unlock the phone first switch off the Nokia 1600 Cell Phone. Remove the battery for 30 minutes. Reinsert the battery and switch on the Nokia 1600 Cell Phone. Enter the default code 12345 or 00000.Your Nokia 1600 Cell Phone will be unlocked.
Oct 13, 2011 | Nokia 1600 Cellular Phone
How to unloack nokia 1616 security code ?
Hi
For unlocking you Nokia need IMEI no of your mobile, send me that no otherwise the use this instruction.
Cheer
Jul 17, 2011 | Nokia 1616 Cell Phone
Nokia 3110 calling time battery empty and switch off
when i power on the mobile show battery empty after show nokia icon then mobile power off
Oct 14, 2010 | Nokia 3110 Cellular Phone
Nokia 1600 suddenly battery low when switch on battery full. solution plz
Sometime replacing of battery is right, it is more costly So you better go to mobile tech or you can do this.78bf4b2.jpg
Aug 12, 2010 | Nokia 1600 Cellular Phone
1600 NOT CHARGING
once check ur batterry pins and also charging pin of the mobile and charger both are working or not........,
Mar 29, 2010 | Nokia 1600 Cellular Phone
I Forgot my Nokia 1600 mobile security code
There is a default password for nokia phone try the 1234 or 12345 if this will not work remove the battery then put it back and press the power button again and try to enter the code 1234 or 12345
Jun 08, 2009 | Nokia 1600 Cellular Phone
Nokia 1600 no net w0rk
nokia 1600 model no network. how to repair it
Dec 07, 2008 | Nokia 1600 Cellular Phone
Not charging
maybe the batterry in the phone, the connector will nto hold charge, either your batterry is stuffed or the charger is, it has nothing at all to do with the phone, or either the phone connectors that run leads to the batterry, the little gold clips that the batterry connectors go to, arefaulty and that means you will have to replace the phone.
Oct 25, 2008 | Nokia 1100
In nokia 1600 display is not displaying
Try charging battery before turning on.
Low battery may have enough power to light display but not for over a few seconds.
Good Luck.
Sep 26, 2008 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
234 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
