Question about Activision Guitar Hero World Tour Guitar Bundle - Xbox 360 Game, Wireless Guitar for Xbox, Xbox 360
After about 20 mins of playing my drum kit just stops working and all the red LED's flash. Im assuming its losing its wireless connection and i am unable to re sync it unless i remove the batteries, but even then it will only last a couple of minutes before it does it again
  • bonita_andy Sep 30, 2009
    I stuffed up my post, should have said it was for ps3, not xbox
  • 101 Answers
Its an XBox 360 error and must be sent back to microsoft for repair contact microsoft for an RMA for return ...this happened to mine
Posted on Sep 30, 2009
    Sergeant:
    Champion:
  • 289 Answers
Call sony support
get a replacement drum kit, i guess there isn't much to it...
Rear drums smell like something is burning and are hot.
remove the drum and inspect you job. small shoe on front big shoe on back.brake lube on the backing plate.lose the adjuster and inspect,lube the adjuster, give more free play on your parking brake cable 3 click is the normal before lock the wheel. Inspect the master cylinder for overfeel, remove any fluid over the max level. inspect the fluid for contamination(burn smell or oily)flush the system. lift the Jeep and pump on the brakes,if the wheel is locking open the bleeder screw.if brake fluid is under pressure,replace the hoses.
good luck
Oct 24, 2014 | 1999 Jeep Cherokee 4WD
My R2D2 interactive juste flash red
hola tengo el mismo problema que tu, cual es la solucion?
Te escribo desde Spain, mi correo jmbiedma71@gmail.com
gracias
Nov 15, 2012 | Hasbro Star Wars R2 D2 Interactive...
It won't sync
Click on the USB small button "after attach it to the computer" one click. While the red tiny led flashing - turn your mouse updown and hit the small button.
When the red flashing led stop - then you connected.
May 16, 2011 | Belkin Mini Wireless Optical Mouse...
I dont know how to connect the wii drums to the game????
i am assuming you have the wireless drums
insert the wireless dongle into the usb port on
the back of the wii turn on the drum kit the switch
is on the bottom of the kit.
Aug 07, 2009 | Video Game Consoles & Games
Buzz wireless buzzers
i tried several times to fix the problem by syncing the buzzers. it never solved the problem. finally i removed the dongle and blew on it very hard. i plugged it back in and retried. THIS ACTUALLY WORKED. i have played several times with no problem.
hope this is helpful.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
XBox 360 wireless controller won't connect or charge
Guys, you really need to calm down... I have the same problem like you.
I'll tell you step by step why the Xbox 360 Wireless Controller won't work.
1. The controller will automatically disconnect during the gameplay, and the charging kit won't charge.
Solution: This is true what I'm saying now... Where you guys brought your wireless controllers in the stores, there was a Frequently Asked Questions book inside the kit. It told you about the importance of the charging of your wireless controller, because Microsoft informed that it's VERY important to empty your battery before charging it, because the charging kit will no longer charge your battery, and the same thing happened to me. So, if you have any questions of your wireless controller, then contact me at my gamertag, NussKarte. I'll give you new information how to fix your wireless controller.
Jun 30, 2008 | Microsoft Xbox 360 Wireless Controller
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
Activision Guitar Hero World Tour Guitar Bundle - Xbox 360 Game, Wireless Guitar for Xbox, Xbox 360 Logo
205 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
