Question about Vehicle Parts & Accessories
My vw beetle does not start after the alarm went off what do i do?
Check for kill switch up by padals
Posted on Sep 30, 2009
How do I turn my anti theft alarm off on a 2001 vw
Sorry, there's no way for you to do that, unless you have access to a VW scan tool like VCDS. If the alarm is going off, you most likely have a bad driver's door latch and it will need to be replaced to fix your problem.
Oct 20, 2014 | 2001 Volkswagen Beetle
Location on fuse chart listt that disconnects alarm system on 2000 VW beetle
Naturally the alarm has a red current wire , try locating alarm module and clipping either red or black wires .
Dec 25, 2017 | 2000 Volkswagen Beetle
Lost remote key to vw beetle. how do i start my car with my valet key
im assuming you mean the little black emergency key.
just unlock the drivers door with it that should deactivate the alarm
then use it to start the engine im also assuming that it still has the factory fitted alarm on it and not a third party alarm any more problems get back to me Hope this helps
Oct 31, 2009 | 2003 Volkswagen New Beetle Convertible
VW Beetle Alarm goes off for no apparent reason
the sensitivity on the alarm itself is too high, or there is something around the car that is interfering with the frequencies that are sent / received by the alarm itself, like other car alarms, power lines (mine actually did it when i parked under a power line) or the alarm unit itself is malfunctioning.
make sure that nothing is around to the (other cars with alarms) or look up under your dash, above your pedals (might have to take the trim plate off) and / or turn the sensitivity knob (flat-head screw driver, or just a simple protruding knob) down. make sure the battery in the remote is good too. if it stil ldoes it after this, then your remote needs to be reprogrammed.
Sep 24, 2009 | 2004 Volkswagen Beetle
Vw beetle won't start
get the ECU checked by an authorised service centre.
Jul 27, 2009 | 2000 Volkswagen Beetle
2000 vw beetle went to start car and battery
Take to dealer. Vehicle needs vag-com to be reprogrammed. Bring all keys with you to dealer.
Have a 2000 VW Beetle. The alarm won't turn off!
My 2000 Beetle does same thing (although not all the time). Just found an internet post that suggests there is a problem in the door lock sensor. I assume you are using a regular key - not
the keyless entry - like I am. He also said that you can disable the alarm (also disables the
keyless entry - which doesn't bother me) by leaving the front door AND the rear trunk open and
starting the car up. Seems to work so far. I will get the door lock sensor replaced and turn the
alarm system back on (not sure how yet), and let you know if that stops the problem.
Jul 24, 2009 | 2000 Volkswagen Beetle
99 VW alarms keep going off , can't stop it and car will not start.
go and get the alarm codes read by a garage(central comforts i believe)it will tell you the last alarm trigger and three before that,fix the problem and you will have your car sorted......it is quite common for it to be the boot catch so get it checked out.....let me know and i might be able too help you........vw trained and twenty eight years experience with them
Nov 05, 2008 | 2000 Volkswagen Beetle
1999 vw beetle
my beetle is fairly stubburn....for example: i tried cranking it with the alam going off and after five times the alarm cut itself off, then i started it and drove off. but that clearly is no valet over-ride because the second and third time didnt work. second time i unlocked the hatchh back and the assenger door and started the engine and it worked. third time....well...still trying.!!
Jul 25, 2008 | 1999 Volkswagen Beetle
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
