Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing Machine will not agitate
All cycles with the exception of the agitator operate properly, but the agitator will not work. Where is the agitator solenoid located? Do you have to remove the tub in order to access the agitator? Thankyou Will not aggitate, will fill and drain but will not spin and makes a horrid sound when in this cycle
  • 5 more comments
  • Anonymous Dec 28, 2007
    Whirlpool makes a noise, does not agitate or spin Drains fine
  • Anonymous Jan 07, 2008
    Our problem is the same as described here -- the washer spins and drains, but will not agitate and it makes a terrible sound when it's trying to agitate. Have tried no steps to fix problem yet.
  • airco Feb 11, 2008
    I have tha same exact problem. Not agitating nor spinning but filling and
    draining.  What is the problem?. Worth fixing? Machine 6 plus yrs old.
  • raider08 May 24, 2008
    Washer will not agitate
  • Anonymous Jul 28, 2008
    machine will fill n spin but not agitate
  • Anonymous Aug 19, 2008
    WASHING MACHINE WILL NOT AGITATE
  • Anonymous Aug 25, 2008
    SPINS AND DRAINS ARE ok BUT WILL NOT AGITATED
Coupler
Posted on Dec 19, 2007
  • 57 Answers
Call your local repair man and tell him you need a drive block. it is like a 30 dollar part. it is worth fixing. it is the new design for a belt
Posted on Feb 16, 2008
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
How to remove agitator in Beaumark Super Capacity washing machine?
https://m.wikihow.com/Remove-a-GE-Washer-Agitator
Jan 12, 2018 | Washing Machines
Will not spin or agitate
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Nov 26, 2012 | Maytag Legacy Series Top Load Washer
Neptune washer will not go past the first wash cycle
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Won't spin
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken.
Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Last the huming may be the motor is sized! Done, finished!
This is not a do it your selfer job
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
-no agitation
Hello
Welcome to Fixya
My name is Huum,
Dec 10, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,146 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
