Question about Maytag MAH55FLB Front Load Washer
Short water fill cycle - Maytag MAH55FLB Front Load Washer
    President:
  • 1,304 Answers
Clean the water hose sc reens
Posted on Oct 05, 2009
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Frequent leaks through soap drawer during rinse cycle
Possible that the dispenser drawer is out of alignment or is the suspect. You can remove and check the mountings
click on : Dispenser
Jan 24, 2013 | Tecnik TKL9260 Front Load Washer
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer fill problem
make sure you have it on the right settings, or inspect fill hoses cold for clogg
Apr 17, 2008 | Kenmore 44042 Front Load Washer
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MAH55FLB Front Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
