the two magic buttons, are located on the side of the plastic. ok after taking all of the screws out...
(More)
the two magic buttons, are located on the side of the plastic. ok after taking all of the screws out like in the other statement, the to button are more like tabs on the side of the housing, but in side on the side. best way to discribe would be to look at where the big wheel that you put the big belt on. look approx. a inch from the big wheel slightly down and you will see the tab that i'm talking about, push this in with a flat head screw driver on both sides and the hood will seperate from the agitator housing. the control for the carpet height is attacted to the hood and will not interfer. ( you want the carpet height to be in the low position and the carpet/hard in the carpet position, this will make it easier to take off the hood. hope this helps, if you get hung up write me back.
I have model number u6616-900 I had the nut that holds the cable that is on the right side of the...
(More)
I have model number u6616-900 I had the nut that holds the cable that is on the right side of the vacuum come off. Can i just put that back on the cable that is left there? Also the roller is effected, I have to push the handle down to get the rollers to spin, poor performance. :(
Vacuum works fine except for the self propell mechanism does not work and it is hard to push. The...
(More)
Vacuum works fine except for the self propell mechanism does not work and it is hard to push. The exact model is Hoover U6617-960Wind Tunnel Upright Bagless Self Propelled.
the self propelled black plastic piece that the cable attaches to is broken. how do i take the cover...
(More)
the self propelled black plastic piece that the cable attaches to is broken. how do i take the cover off to get to the piece and replace it?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
