Question about Canon PowerShot A40 Digital Camera
Canon powershot a-40 camera
The select wheel has gotten so hard to turn. i am having to use a pair of scissors to turn it
  • xcvii90 Jan 01, 2008
    Yeah, mine too. I can sometimes get it to turn by running a business card around the perimeter of the wheel and blowing on it hard, but that lasts for one turn. My wife can't even budge it, and is screaming at me to get a new camera, but I hate to buy one when this is the only thing wrong with this one.
I had this problem too. For me the problem was that the camera was splashed by some coca cola.
I had to open the camera detach the knob from the case and clean the knob and case with a damp cloth. Worked fine after that.
Posted on Jul 21, 2008
I need the drivers of this camera please help me
Posted on May 04, 2008
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
I HAVE ACCIDENTALLY SELECTED BLACK AND WHITE. hOW DO I REVERT TO COLOUR?
Press the FUNC/SET button. Use up/down to select "My Colors" (the palette icon, fifth from the top). Use left/right to select something other than "B/W" for black-and-white then press FUNC/SET.
Dec 14, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
I have a Canon IXUS 40 and i want to turn on the digital zoom
Hey!
Kindly look at your camera's User Guide. On page 72 you'll have the instructions on how to turn the digital zoom on/off.
Best regards,
Pelu.
Apr 07, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
I need to know how I go about getting another manual for my canon 10x.
Canon made several digital cameras with 10x zoom. Go to this link, and select "Digital Cameras" next to the number 1.
If you have a PowerShot SX100, SX110, or SX120, select "Other PowerShot" next to the number 2, and then the model next to number 3. Click Go.
If you have a PowerShot S1 IS, select "PowerShot S Series" next to the number 2, and then the model next to the number 3. Click Go.
If you have a PowerShot Pro 90 IS, select "PowerShot Pro Series" next to the number 2, and the model next to the number 3. Click Go.
You will be linked to a page that has the manuals for the camera.
Nov 23, 2009 | Canon Cameras
"lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
Oct 11, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
Cannot delete photos on Canon Digital Ixus 40?
here is the link to the download the manual. go to the drivers and downloads section and scroll down until you see the user manual it will let you download it. hope this helps you!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=9826#DownloadDetailAct
Feb 11, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Can t see pic saved on the card on the lcd screen
Did you accidentallypress the DISP button on the back of the camera? Try pressing it to see if it turns the display back on.
Jan 25, 2009 | Canon PowerShot S2 IS Digital Camera
How do I get the date to print on the pictures
To set datestamp to appear on your pictures:
Hit FUNC SET (middle of wheel on back)
Hit Right side of wheel to SELECT the mode you would like to have (Auto, Man, etc)
Hit Bottom of wheel to get to bottom of Left Menu on screen
Hit Right side of wheel to SELECT fifth selection (Postcard 1600x1200)
This is the only mode I have found that supports the date stamp on the Canon Powershot SD600.
P.S. Don't forget to set the correct date and time in the screen MENU under the Tools tab!
Nov 07, 2008 | Canon PowerShot SD600 Digital Camera
Canon PowerShot A40 Digital Camera Logo
103 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
