Question about Dryers
Dryer has no power
No power to dryer. No lights on, will not turn on. But the back is warm. I have checked the fuse box in the house and all seems well.
    President:
  • 1,922 Answers
Do you have 240 volts to the dryer, if you lose 120 volts on one side it wont heat fully
Posted on Oct 04, 2009
Dryer will not start the led light are off
Hi maike, this is AP!
Often when a product does not start I would recommend starting with the power source such as the breaker feeding power to the dryer. There are two house fuses that supply voltage to the dryer circuit in your fuse box. Check and replace the fuse in the fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the dryer may turn but will not heat.
For your particular Frigidaire dryer, model FARE1011MW, if the power source is not the culprit the control board could be defective. Another source of the malfunction could be the door switch, however I would think you would have power to the control panel if that was the case. If your appliance is still in warranty, you may want to check with the manufacturer to determine any warranty coverage, or if there are any professionals in your area who will not only be able to ensure this is the appropriate fix, but may actually save you some cost if is something simpler to repair. I hope this information helps to some degree.
Thanks,
Apr 02, 2014 | Frigidaire FARE1011MW Affinity High...
Buttons, sounds, lights all go on but the dryer will not dry
Hello toofdr - Often this occurs because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn on but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The timer will not advance, it heats up on the correct settings, but will just stay on indefinately. Sounds like a classic Timer issue, but just want to ask for a second opinion, and ask what the part...
We have a dryer ( could be any make! ) that is consistently blowing fuses after about 15-20 minutes. We have taken the dryer apart to check for clogs in the venting system and to check if the heating core was okay and they seem to be fine. Any ideas?
Blowing the house fuses? If yes....the dryer usually will blow a fuse right away if there is a problem in the dryer....more often than not a fuse that blows after the dryer has been running a while it is a fuse box issue. A test: Put 2 new 30 amp fuses in and run the dryer with the heat on for 5-10 minutes, turn off the dryer and quickly remove the fuses from the house fuse box and see if they are hot at all ( especially on the bottom )....if the fuses are getting hot they are probably melting the fuse link and not really blowing = fuse box problem.
As for most things there are exceptions....a grounded heating element -may- blow the fuse after the dryer has been on for a while, it is easy to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a problem.
Dryer basics- Venting problems and power supply:
Most dryer "to long to dry" or "poor/low heat" complaints can be traced back to a bad or poor venting system and sometimes a poorly maintained lint filter. Do not go outside and put your hand under the vent opening and say " it is fine - I feel air coming out"...that is not good enough...take your venting apart, clean it ALL out and make sure the vent hood flapper works and that it is not clogged with lint. Make sure your venting system is short, straight and resistance free as possible. A poor venting system will shorten the life of your dryer, plug up the fan blower and duct work inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer. Electric dryers need 240 volts to operate the heating element and 120 volts to operate the timer and motor. You should see 240 volts between the black and red wires, 120 volts between the red and white wires, 120 volts between the black and white wires at the electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still allow the electric dryer to run but you would get no heat. Depending on which fuse goes, sometimes the dryer could be dead as well. If you have problems with a fuse letting go or a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
Dec 16, 2010 | Dryers
When I first turn on my dryer nothing happens like I have a blown fuse. When I unplug and plug cord back in light comes back on and dryer either "hiccups" and loses power or runs for a half cycle before...
Turn the breaker off (or remove fuses) at electical box. Remove cover from dryer recepticle and look for loose wire(s) or other sings of a poor connection. If all good there, check for the same at the circuit breaker / fuse box. Also check that the power cord connections are tight where it attaches to the dryer.
Feb 07, 2010 | General Electric DHDSR46EGWW Dryer
Dryer just quit running. power cord was replaced
If you have a fuse box in your house I would check the fuses for the dryer. The dryer runs on Two 30amp fuses.
If your house is on breakers. Shut the breaker off for the dryer and turn back on and test.
Hope this helps
Dec 31, 2009 | Dryers
Dryer will not run at all. It seems to have power going to it though. Any thoughts?
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Jun 14, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Dryer will not turn on
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Door switch
Thermal fuse
Wiring
Dec 15, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
