Question about Kenmore Kitchen Ranges
Kenmore gas range, loud boom sound when igniting,how to use clean
When the stove ignites it is very loud, almost like a mini explosion that causes alarm, also we were suggested by landlord to use clean option to see if lessens the boom when turning on oven....we do not have manual, how the heck do you clean...just push ''clean'' button??????
    President:
  • 1,304 Answers
Dont clean
you have a weak ignitor
and this is very bad
it should be replaced quickly
Posted on Oct 06, 2009
My Kenmore Gas Range 790 makes a puffing sound every time the oven cycles on. Sometimes it is quite loud. In addition when I set the temperature the preheated beep sounds well before the temperature
It sounds like your oven igniiter is the problem. the part that glows in the oven. they get old after a few years and you can get a miner explosion when the burner lights. Replacing the igniter should fix this.
Nov 06, 2014 | Kitchen Ranges
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Oct 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The electric panel on my smooth top stove just went out with a popping sound rendering the oven unusable but the stove top burners are working.............what could have happened and is it worth it to get...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 21, 2010 | Kenmore 95423 Stainless Steel Electric...
I have a kenmore gas range model # 665.75775 the strikers work to light the burners but they will not light do I need to clean the burners and if so how
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jun 19, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Oven is slow to ignite, gas builds up, then
this is potentially serius and if you cannot rectity fault by simple cleaning then you must call in a registered gas engineer.
remove oven trays and any cover plate at base for access. Check the ignion lead from ignitor (either electronic or manual piezzo) and the ceramic electrode that lead goes on to. if there is any short circuit it will not spark. most common fault is dirt etc around the area of pilot or ingitor causing delay with resulting explosion after area becomes saturated with gas, take a brush and clean all you can. I cannot advise to strip down any gas parts as this must be done by registered engineer
Dec 21, 2009 | Kenmore Kitchen Ranges
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Explosion potential
Absolutely do not use it until the problem is taken care of. You do indeed have an explosion hazzard.
95% chance all it needs is a thourouch cleaning of the ignition assembly.
When burner orifices and lighting tracks get contaminated and partially clogged with rust, dirt, and other sediment it starts to block the gas flow.
The gas starts to build up unburnt untill it eventually encounters the flame or ignitor, and then all the built up gas ignites at once.
It would eventuallty get worse.
Clean or replace the ignition assembly and burners.
A brass wire brush works wonders.
Jan 11, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
550 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
