Question about Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace the idler pulley.
  • triplenotone Sep 30, 2009
    I did as mowerman 1857 suggested and kept getting "0 results" for my Model Number. This mower is a 15HP rider w/ a Tecumseh engine in it. It has a 42" mowing deck attached. The Model Number is 42702X99A, which I cannot find anywhere in the listings. The mfr date is 0333. We inherited this mower from my wife's late uncle, and we would like to keep it running if possible.
  • Anonymous Mar 18, 2014
    murray 8-31517x20. the idler is being pushed around behind the pulley splined. Where they meet the idler is missing a part?
  • 389 Answers
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
  • Chuck
    Chuck Sep 30, 2009
    http://www.partsandservice.com/bin/ipl.c...
    OK Try this one. I know it works because I have it on my screen right now. If you can't get it to load on your computer send me your email and I will send it to you. remove all the spaces and use proper format in my address below :
    m o w e r m a n 1 (at) h o t m a i l (dot) c o m
    I'm sorry Murray doesn't have EVERY tractor they ever made on their web-site!
    Problem Solver:
  • 8 Answers
The mower deck drive belt slipped off the idler - mower-deck-drive-belt-slipped-off-idler-yf3zdllwco2f1yp5d1drasa2-2-0.png
  • Displaying Motion Drive parts for the Murray 42560x92B - Briggs/Murray 42" Lawn Tractor (1997) (Walmart)
  • Displaying Mower Housing parts for the Murray 42560x92B - Briggs/Murray 42" Lawn Tractor (1997) (Walmart)
Posted on Feb 13, 2016
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How to repair clutch on Murray riding lawn mower 465306X8B
465306X8B - Exploded drive belt parts view.
Jun 26, 2015 | Murray Garden
Replace belts on 917-271821
The deck has an idler pulley that keeps tension on the belt. The idler pulley is mounted on a pivoting bracket, that has a spring which provides the tension. You have to move the bracket so as to take the tension off the belt, thereby allowing you to slip the belt off the other drive pulleys
Aug 15, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How to change dive pulley for 944602660?
This is likely due to a worn and slipping belt. Replacing the belt should solve the problem
Aug 03, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John deere x300 will not move
It sounds to me like the traction drive belt slipped off of a pulley or broke. The easiest way to get to the traction belt is to remove the mower deck. There is no easy way to replace the belt, however. It runs from the transaxle at the rear to the engine at the front, around idlers. Let me know if you would like assistance in replacing the belt and I can walk you through it, Daniel.
Oct 07, 2011 | John Deere 22HP Hydrostatic 42" Riding...
19.5 hp 42 " automatic craftsman . The trans seems to be slipping,does not want to go up any incline. I have purged it and installed a new drive belt. did not help.
recheck ur drive belt either wrong belt or spring/idler/tentioner pulley needs attention adjustment replacement also check free wheel actuator that not partially activated
Jun 10, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tractor belt slips so blade doesn't cut
There is an electrical clutch that drives the belts. This clutch may be worn. Some will have adjustments that will allow it to tighten them up and not slip. Now when your tractor is running and you turn on your blades there is power sent to this clutch, it is mounted on the engine shaft and has flexible metal plate that is pulled into a pulley buy an electro magnet this plate is worn or could be full of grass/dirt. You need a good strong light, with the tractor OFF, get under and look at this clutch, look for grass/dirt or if the metal has changed colors meaning it has gotten very hot. If it has gotten very hot it is time for a new clutch... Sorry if this is the case. Good hunting.
May 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
My Sears 917.272911 Lawn Tractor is eating mower drive belts. The belt is being worn out in minutes on the flat idler pulley side. When I put the old belt back everything seems to work fine. The new belts...
There's a couple of things that could be causing this. First, make sure the idler pulleys and blade pulleys spin freely. Second make sure the belt is behind the belt keepers on the two idler pulleys. There is only one on the left idler, but TWO on the right idler. I suspect that is your problem. Anyway, once the belt is on, engage the blades, with engine OFF, and inspect the belt routing, making sure it's not over or under something it shouldn't be.
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
1,158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
