Vacuums
Problem for Vacuums
Generic problem for all Vacuums
Bissell Healthy Home
By wibadger81 on Dec 19, 2007
I have a bissell healthy home vacuum cleaner which was purchased about 6 months ago. It has lost suction power signicantly. I have emptied the canister and there are no blockages I can find. Is there a filter somewhere that could be clogged?
Same Problem
Apr 29, 2009
-   My bissell won't turn on the motor goes on but the brush is not on when its suppose to be.....I cleaned it recently and found it does not work now. I think that the vacuum is good but that there is a flaw in the design.
Suzanne in Benicia-   Guest
Best Solution
posted on Mar 01, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue after using it daily for over a year. I checked everything and found no clog. I brought it to a vacuum cleaner repair center and they found a clog in the motor. It cost me $25 and was well worth it. I love this vacuum
Solution #2
posted on Jan 02, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
1. Make sure the hose attachment is pushed all the way down into its receptacle. It will click softly when it's all the way down.
2. Detach the hose from the machine. Do this by twisting the grey fitting on the back of the machine. (Note: leave the attachment end of the hose plugged into the machine) Turn the machine on. Hold your hand over the hose fitting. If there's strong suction then there is a blockage in the hose.
3. If not, check in the fitting to see if something is stuck in there. On the back of the machine there is a long clear tube that travels down the back of the machine. Sometimes larger peices of paper get stuck in there. If something is in this tube, take a phillips screwdrive, remove the 7 black screws off and remove the blockage. Reassemble and try the machine.
4. There are two filters on this machine. The one that may be clogged and affecting the suction is located below the canister in the front of the machine. Simply pull ouot the tray and reomve the grey foam filter to clean. Rinse it out with warm water then allow it to dry. Replace in its tray then slide the tray back into the machine. The other filter is the HEPA filter and has nothing to do with the suction of the unit. It is an exhaust filter and does need to be changed at least once a year. It filters the air coming out of the machine. The first few times we used ours the whole house smelled "clean". Whne a new filter is placed in the machine that "clean" snmell returns. The filters are $25 apiece at Amazon.com.
5. As a maintainence item, remove the canister as though you were going to empty it. Place it on the ground, locate the two buttons (one clear plastic/one blue) on the front and back of the canister and remove the clear plasctic housing. This will allow you to clean the hundreds of little holes on the grey surface of the top of this section. (This looks like a circular colender.) To clean this, use an old toothbrush and scrub the dust and stuff into your grabage can. I do this once or twice a year. (Since I have a Shop Vac in the garage, I use this instead of a toothbrush.)
Hope this helps.
Solution #3
posted on Jan 14, 2008
Not Helpful)
LizDahl
Rank: Wiz
Rating: 81%, 86 votes
Personally I would look at possibly getting a more solid machine, I have found alot of my customers have a similar problem that is recurring.
Was this helpful?
Yes
No
Popular Solutions for Vacuums
Questions and Unsolved Problems for Vacuums
Answer
what type of battery does this vacum have. Also what is the voltage.
Answer
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way.... (More)
Answer
After removing the filter to clean, the vacuum is not picking anything up and will not work when... (More)
Answer
This seemed to work well until almost a year of using it I became very sick. The dust comes out on... (More)
Describe your Vacuums problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
in , AK
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
