Question about Kodak EasyShare C613 Digital Camera
The zoom on my camera will not close. in not
The zoom on my camera will not close. in not doing so it causes my camera to turn off as soon as its turned on. how can i open my camera to fix it to where my zoom comes out and in.
Nightdiver
  • 116 Answers
SOURCE: not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
Posted on May 31, 2006
Gurudristi
  • 98 Answers
SOURCE: my camera won't stay turned on
Its possible that dirt, sand had got stuck between your lens barrel and the body and that why the lens is giving you problems.
You can try some of the following solutions to help you out:
1).Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5: Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont try very hard please.
Try the above and let me if its any help.
If the above does not help. Then you would need to take it to the nearest service center.
Posted on Mar 08, 2009
leorcid
  • 281 Answers
SOURCE: the camera turns on, zooms then goes off
Looks like your zoom button is stuck. Try pressing both the W and T sides several times keeping the camera off. If this doesn't work, you'll have to go for a service center.
Posted on Feb 15, 2010
yo5bdm
  • 81 Answers
SOURCE: my camera turns on but as soon as i try to zoom it
This could be a software problem. Re-installing the software of the camera could do the job. You have to go to a specialised Kodak electronist.
Posted on Apr 08, 2010
slimboga
  • 82 Answers
SOURCE: The lens opens up and then closes up right away
this is sovent a pressure on the lens problem...is probably that you must change the entire lens bloc. if you have eletronic knowledge, you can prove to find on ebay international seller the replacement for you camera. to the international seller with the exact model number search "lens for ...your model number" any seller if you buy the lens give you a guide to instal the new lens. but if you dont have idea where you makes the hands...its better that the work makes a professionist. if you want prove alone...it s possible to make the job but if you make errors you loose the camera and the cost form the spares. the better system is to find a brocken camera on ebay. but you must be shure that the camera have not lens defekt. so you can disassemble the broken camera, see how you can disassemle the lens bloc and reassemble on your caMERA. THE BEST IS FILM WITH ANOTHER CAMERA THE DISASSEMBLE OF THE BROCKEN..THIS CAN HELP YOU IN THE MOMENT THAT YOU REASSEMBLE YOUR CAMERA.
sorry for my bad english good luck
Posted on May 30, 2010
Non-zoomed pics are in focus but as soon as I zoom in, even slightly, pics get very blurry. What settings should I be adjusting, please?
M stands for macro.this is for extreme close so dont take photos with m displayed unless extreme close
Jul 06, 2015 | Sharp Cameras
I have just purchased a canon eos 600 digital camera.efs 18-135mm lens All excited.\r\nBought it home and on autofocus can't zoom the bird on the dam up very close? I can look through my point and...
Your not doing anything wrong, your Panasonic probably is using digital zoom (which is basically just cropping the picture imitating zoom). Your eyes sees similar to a 50mm lens so your 135mm lens is less then 3x zoom.
Do not be discouraged you will soon learn your cameras strengths and weakness.
Good Luck
Jun 15, 2011 | Canon EOS 60D Digital Camera with 18-200mm...
I suspect moisture in the lens on my digital camera when I use the zoom. The picture is very foggy. When I don't use the zoom the picture is fine.
Hi! Your suspicion can be right but the other thing that can cause this is that the optic lens itself on the zoom is faulty. You may try to have it replaced now or soon. Just wait for the lens break point to maximize the usage, not unless you always use the zoom. Hope this helps and thank you for using FIxYa!
Aug 31, 2010 | Sony Cybershot DSC-S950 Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
DSC-W80 zoom extends, shutter opens, closes, zoom closes, 5x, won't work
Hey kbcinc,
I would try taking the battery out and waiting a minute and then reinserting the battery. Another option you have is to try and reinitialize the camera, but you would need access to the settings menu on the camera and it doesen't sound like you do. To initialize the camera go to main settings 1 and choose initialize. If this doesn't work I would bring it to an authorized service center to have it looked at.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 11, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Zoom goes into automatic pilot
Try take battery off camera while operating recording mode, amd put it back without turning off camera. I really do not know why this happend, but this solved my Canon mvx330i "by it self zooming" problem. try turn on digital zoom in meny and take of battery...
Nov 08, 2007 | Canon MVX330i Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Sony DSC-S500
you are right it has defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 11, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
