When u put the heater on auto it will not work. when u put it on the on postion only the blower works and not the heater. what do u suggest ?
  • 24 Answers
Remove cover to thermostat and find the RED or Rh terminal and jumper it to the W or heater terminal, Rh is power ,W is the heat relay , if your heat comes on you know your equip is good, if so change thermostat
Posted on Sep 30, 2009
I have replaced my blower motor and relay switch and my heater still won't work. what can the problem be?
Did you test the electrical circuit before replacing parts . Testing is the proper way to fix automotive electrical problems . Suggest if you want to fix your own vehicle you learn how . Blower Motor Problems Auto Repair Help Don't give auto parts stores free money . Maybe you should take it to a qualified repair shop .
Jan 22, 2017 | Cars & Trucks
1995 Isuzu p/u truck keeps blowing out the 20 amp fuse on the heater.
sound's like a earthing problem , try a continuity test from blower LIVE to chassis , if get continuity then def got a wiring problem , very difficult to diagnose without seeing vehicle , get a auto electrician
Jun 11, 2017 | 1995 Isuzu Pickup
Heater/ac blower ...all sound no blow
or you trying to use the A/C if you are then have the compressor checked and the freon level checked also last summer had the same problem with my truck gave it a quick charge and it worked just fine so they maybe the problem
Mar 18, 2012 | 1996 Volvo 960
Heater blower doesn't work - 2002 Jeep Grand Cherokee
Could be module check with the dealer where is.
May 03, 2017 | 2002 Jeep Grand Cherokee
Only works on high speed (fan switch)
It sounds like the blower resistor needs to be replaced. Auto Zone will have the blower resistor that you need to replace and will have the step by step instructions for you to get the job done with common tools and will take just under 2 hours if your good with tools. Good luck and keep me posted, the cost of the resistor it self is around $27.00
Nov 16, 2009 | 2003 Oldsmobile Alero
Heater only works on high
http://www.gtrippleb.com/auto/durango/tech/durango_blower_resistor.htm
If the blower motor only works on high then it is the blower motor resistor. The link has pictures how to find and change it. The part is about $12.00
Jan 17, 2009 | 2001 Dodge Durango
2000 Town Car AC Blower working off and on
You are going to have to replace the Auto climate control assembly in the dash.
Jul 08, 2008 | 2000 Lincoln Continental
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
