Question about Cameras
Ic error on digital camera - Cameras
I have a Canon SX 30is. When I press the power button, I get an E10 error message, and then the camera never turns on. How do I fix this?
Unfortunately, canon tends to use the same error codes across models...particularly the E10 error code which indicates a JPEG IC error. Basically, the image processor has just given up. I don't know of a way to fix it other than to completely dissect the camera and replace the entire board. Definitely not the news I wanted to deliver but I've seen that error on three separate cameras, and opening up the firmware files for each indicated E10 as being the same error. Any chance its still under warranty?
Sorry to be the bearer of bad news, but I hope that helps!
Oct 23, 2013 | Canon PowerShot SX30 IS Digital Camera
Intova ic12 green error message on viewfinder shutter not closing any help
Hello jan_c19,
This sounds like a defective IC12 camera. Please contact Intova via email, fatema@intova.net or call us at 808-837-0074 for customer service. Thanks
Jun 02, 2012 | Intova Ic12 Digital Camera
Er 95-120 what can i do?
This Error 95-120 it means error of digital data (2) input from the RC IC (DPR-141A board/IC310) to the NFL IC (DPR-141A board/IC505).It will only come if had drop it or u had bang when u where using it.
checked all the flat cable.
Mar 08, 2011 | Sony Dvcam DSR-390P DV Digital Camcorder
No power, camera won't turn on!
If the battery is good and charges and if there is no way in which the camera is coming to life then it is possible that there is a fuse link failure within or a control board error, the first part can be checked by opening the camera with the proper tools and checking from the battery power, but if thei seems ok an dpower feeds to the controller board, then the IC can be faulty.
Sep 29, 2010 | Kodak EasyShare CX6200 Digital Camera
How to fix the error problem in nikon d80 camera?blinking error message at the left side on the top line on display screen,ill try all ways to fix but it dsnt work,ill open the camera and align inside the...
Hi ktithender, on the left side top of the LCD on the top of the camera is the battery display and the Auto ISO display. What is it you are seeing as an error message? Also, if you are opening, taking apart the D80 there is not much any of us can do to assist you. My suggestion is to call Nikon 800-645-6689
Aug 18, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error message at display screen
Set both the exposure dial and the focusmode to "M" and press the shutter button. Then turn the camera off for 10 - 15 seconds. If this doesn't solve the problem, it's an electronic or mechanical error.
Jul 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
Error E 62:02 and only one message turn power off and on again
Hi, This error detail is given below. Symptom/State : Abnormality of IC for steadyshot. Correction: Check or replacement of the IC for steadyshot (IC503 on the SY-194 board). Thanks for using fixya.
Jun 03, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Cameras
I took mine to an authorised repair center,but was of no help. The error generally shows due to IC problem OR the head has some issue. Do not try any DIY.
Feb 14, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Problem with Sony Cyber-shot DSC-W55 Digital Camera
wll friend flash your phone with cruiser with latest version and yet it dont work change the camera lens not yet heat camera ic and finally last solution is to change the camera ic. enjoy
Aug 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
