My monitor's resolution changed overnight and everything is ginormous and off-color, and I can't change the resolution through the control panel and I've already tried system restore. What else can I do?
    President:
  • 2,600 Answers
Sounds like you may have had a bad system update overnight. Try going to the device manager through the control panel. IN XP you get to through System and then the hardware tab....anyway, find the graphics adapter and try to roll back the driver to the previous one. This may clear up the settings issue and allow to make changes. If that doesn't work, try uninstalling the graphics adapter and reboot. This will force windows to recognize the hardware on reboot and load fresh drivers for it.
Posted on Sep 30, 2009
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
Change default monitor
You should download and install the latest drivers for your graphics card and your monitor will automatically adjust the best resolution for you.
Jun 08, 2014 | Dell S2409W LCD Monitor
Change display properties
To change your screen resolution
  1. Open Screen Resolution by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  2. Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  3. Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
c976c8e1-2a05-4209-a850-ea7c43422c04_50.jpgScreen Resolution in Control Panel shows the recommended resolution for your monitor.
Aug 27, 2012 | Computers & Internet
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
How to set the display settings
Make sure the video driver has been installed.
Go to Start - Control Panel - Display - click on Settings tab and change the Screen Resolution, Start with a resolution 1024X768 with 32 bit color. Increase the Screen resolution higher if required to suit your needs.
Jun 14, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
Images Stretched
go into control panel/display and check your resolution. It sounds like the resolution may need to be changed. You can try 640X480 or 600X800 and see if that makes a difference for you.
Aug 11, 2009 | Acer X191WSD Monitor
Color Problem
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
May 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
Computers & Internet Logo
244 people viewed this question
David Payne
David Payne
