Question about Maax URBAN 7242F FREESTANDING BATHTUB - 102611-000-W - White
Resufacing an old bathtub
I understand that an old bathtub needs to be sandblasted...But can any home handyman do it himself at home...Or are there special chemicals and processes needed to finish the job, that only professionals have?
    Brigadier General:
  • 3,006 Answers
The answer to this depends on whether you intend to have the bath re-enamelled (vitreous enamel) or whether you intend to use one of the proprietary DIY roller paint "enamelling" systems.
If you plan to have vitreous enamel then any company doing it will not guarantee the outcome or the finish unless you have them do all of the preparation; typically they'll blast the tub back to completely bare steel/cast iron and chemically wash it afterwards. Without this there's a good chance that when the tub comes out of the kiln there will be pinholes (a.k.a. birdseyes) in the finish. If this happens after they've done the prep they'll re-blast it and start again if need be, but not if it's your fault.
But if you plan to use the DIY system then all you need is a smooth and clean base so you can hire a blaster and do the job in your own workshop. Fill any pitting left by rust before repainting the bath, lead or two part epoxy car body filler do the job just fine. DIY kits don't give a great finish but they do look far better than a tired bath with chipped/cracked vitreous enamel if you can't afford to get the job done properly.
Posted on Oct 01, 2009
Testimonial: "Awesome...Thanks for that...It was about $1200 to get it done professionally. But a new one is going for $800-$1000 on the net. I will give it a go."
Where can I BUYold eljer bathtub drain plug
Try Home Depot or your local hardware store. Or eBay.
Feb 17, 2014 | Plumbing
2425elho020
You will need to check with the Mfg of your bathtub for new skirt.
You may find a generic front skirt at your local hardware store i.e. Lowes or Home Depot.
US Parts Center
Aug 24, 2013 | American Standard Colony Hydro Massage...
3 piece tub needs to re-caulked. Is this a do it yourself project?
Are you talking about caulking around all sorts of small tiles, or is yours a one piece wall unit that only has caulking around the edge of the tub and the nozzels? If it is the latter, you simply remove the old and add new. If it is all the old tile caulking then If you are not good at handyman (handywoman) things, then you should call a professional. Most of the home outfitting places have help available to you if you wish to DIY the job. You should visit a place like Home Depot, Lowes, etc. for their free advice and a lot of them offer classes in home repair things.
Jan 26, 2013 | Home
Sanblaster gravity feed bad media flow
Check that the new gun is compatable with the media you're using in your sandblaster. If you just replaced an old gun with the same kind you should be OK. Check that there aren't any peices of "stuff" in the line to the gun or where the line enters the sand. Next, make sure you are using dried air. Compressing air causes the water (humidity) to condense out and pool in the tank. This water then makes its way through your air lines and to your gun. If the air isn't dried by a filter somehwere on the line the moisture will mix with the sand and make it flow like you describe.
Jul 22, 2012 | RTO Gravity Feed Sandblaster
Recently installed Toto toilet by a qualified plummer(twice) it still rocks side to side and back and forth. Floor is level. Toto Toilet Aquia11
Qualified? Plumber? sounds like it needs to be shimed,because not all floors are exactly level,or castings of toilets exactly perfect.Doesn't sound like the handyman knows what he's doing.Shims available at home depot--plastic-don't shim with wood-it will rot.I've used various coins to get right thickness.Be careful tightening bolts,you'll crack bowl.Find a legit plumber licensed
Feb 15, 2011 | Home
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Can bottom of bathtub collapse
The answer is yes.Most of your moble homes have poly or fiberglass tubs with litttle or no bracing under them and the floors are made out of a fiber type board. When they get wet they warp, crumble and fall apart, so if water has gotten under the tub there isn't much of a floor under it. But yes it can be repaired. She will have to remove the old tub and the wall board around it And probably have that portion of floor replaced.
Dec 02, 2009 | Home
The on off button presses down but not up and the a irflow does not go on. It is less than a year old and the construction men purchased it at Home Depot. Since they left no papers with me, is there any...
This tub should certainly still be under warranty if it is less than a year old. With my business, I offer a one year warranty that is standard with all of my installs. You may want to try your contractor first to see if he/she offers a warranty. If your contractor did not offer you a warranty, you may call American Standard @ 1-800-442-1902 mon-fri. from 8 am-6pm EST. If you have to go through them, the part should be under warranty, but you will be on your own for the labor portion. I would still check with my contractor first. I do not know any contractor that does not offer a one year warranty. Unless this was just a handyman and not a professional contractor.
Nov 20, 2009 | American Standard Home
My pearl whirlpool bathtub has turned on mysteriously when no one is home and no water in the tub...only one years old! Is this a sensor problem? Motor problem? touch-pad control problem? Please help, I...
Sorry, didn't realize I would need to pay money for the answer. I will deal with Pearl bath on my own. Thanks for the help, please remove my email from your mailing list.
Nov 02, 2009 | Whirlpool Pearl Ballade True Bathtub with...
Broiler won't ignight - 48" gas range
I had the same problem. I'm not a handyman. A repairman came out and had to replace the igniter. Had to order it from Europe, which took about 2 weeks. They get old and crack and don't work after a while, he said.
Oct 27, 2008 | DCS RGS-486GD Gas Kitchen Range
Maax URBAN 7242F FREESTANDING BATHTUB - 102611-000-W - White Logo
112 people viewed this question
Top Maax Plumbing Experts
Donni Steen
Steve
obsteiner
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
