Question about Motorola Mobility RAZR V3
Water damage I don't even know how water splashed on my cell phone from the jacuzzi, but somehow a few drops managed to find their way, thus damaging my phone. I immediately took out the battery and tried drying everything I could see, including the sim card, all visible connections, as well as the battery and battery cover. I still wouldn't start so I thought maybe the battery had drained and it mearly needed to be charged. I tryed this a few times cuz each time the phone acted a little different, but unfortunatly none resulted in it ever starting up. I had heard that there was a way to rest it. Is that possible and/or are there other options. Thank you for your time and help, Jim Ott imkingottman@yahoo.com
Your best bet is to not do anything to it(besides taking it out of the water that it fell into), wait a couple days for it to dry completely and then turn it on.
Posted on Jan 04, 2008
Buy a new phone
Posted on Dec 20, 2007
Mu Samsung J3 does not download since a couple of days any multimedia message. Always says Failed to download attachment from mutlimedia message. Try again later. Am on wifi, thus no data problem
1) do you have a SD card? if yes, check space alloction. If No then it will have failed due to no space.
2) check to see if download manager is working.
3)make sure you are connected to wifi.
4) has it been dropped many times? water damaged? someone else play with your phone?? the latter will always be the problem as they like to believe they can make your phone run faster.
Feb 11, 2018 | Samsung Cell Phones
Tip
How to fix a phone that dropped into water
Hi, when ever a phone drops inside the water, First you will need to remove the battery from the cell phone.If the battery is left inside the cell phone, the water will damage the cells inside the battery, why?, because there is still Power inside the cell phone that can damage the battery cell.
To service the phone,you will need to unscrew the cell phone,because has entered into the cell phone and it can damage IC chips inside the cell phone if not attended to immediately.
Use a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.(depends on the type of phones)
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone. battery might be dead or low in power..Better you can have a spare battery around
after servicing the cell phone..
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
That's solves your problem.
on Sep 15, 2011 | Cell Phones
My phone drob in water what can i do
try putting it in a bag of dry rice for a few days. it will take the water out of phone. remove the battery if u can. my son dropped my new iphone in water and this fixed it
Apr 06, 2014 | Nokia C203
My iphone 4 drop in my dishwater with bleach will it dry out and work again
Dropping a switched on cell phone into bleached water will certainly damage the electronics in the cell phone.
You can remove the battery and dry it out, but most likely it is damaged beyond repair.
Mar 10, 2013 | Apple iPhone Smartphone
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
How do I make my EnV3 stop vibrating?
Take out the battery and put the phone in some rice. It should help completely dry your phone out.
Dec 04, 2011 | LG enV3 VX9200 Cell Phone
I have a Samsung B2100... It has water under the screen....
Ok , but i don`t think it will recover, water is the worst thng for mobiles.
Firstly remove the battery cover and the battery, dry both with kitchen towel.
Now take all the parts to a warm room , leave for 24hrs then retry.
Fingers crossed for you!
Dec 13, 2009 | Samsung B2100 Cell Phone
LCD reads download
please describe in detail "How you dried it"
I f you ever drop a cell phone in water 1st thing you do is pop the back off and get the battery out.
then shake the water out as best as you can.
leave the back off and battery out for 48 hours. Dont use an oven or Sunshine or a heater or even a hairdryer. After the 48 hours insert the battery and try it out. Most people make the mistake of trying it on withing an hour or two. that just shorts out parts of the phone and permanently crippling it. Following the above procedure for proper drying is your best chance for minimal damage done to any cell phone. Splash-- uh oh! Pop that battery out ASAP! Hope this helps and tell a freind what to do if it happens to them. (it happens ALOT)
and good luck...(sorry)
Jun 09, 2009 | Samsung SGH-Z240 Cellular Phone
I dropped my k850i in water. It started gradually working properly after a few days but it wont charge. Everything else works fine. It just doesn't recognise the charger which I know is working fine.
The phone really does need to be taken apart and cleaned properly using PCB cleaner and any IC's which are damaged need to be replaced, the more you put power into it before the damage is cleaned/repaired the more you are risking further damage...
If you havent done phone repairs before, try a decent local phone shop see if they can take a look at it for you.
If you want to try yourself let me know and I can try and find a guide for dissassembly for you, however I have to warn you a lot of the repairs we get everyday where people have done more damage to their phone by trying to repair it themselves, they are usually unrepairable or cost a lot more as more ends up being damaged than the original fault
May 09, 2009 | Cell Phones
Cell phone dropped in water - red dot showing - options?
you don't need to actually drop your phone in water for there to be water damage.
simple things like having your phone in the rain, in the bathroom while you shower, around a hot tub, or possibly even if it's really humid outside can set this water damage sensor off.
it just gives phone companies more ways to void your warranty.
hope this helped.
Sep 08, 2008 | Cell Phones
Motorola Mobility RAZR V3 Logo
138 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
