Question about Panasonic PT-43LC14 43" Rear Projection HDTV
For about 4 weeks in have been getting a notice when I turn the tv on about a lamp timer needed to be reset. While the TV was on it cut off by itself. This is a panasonic 43" rear projection LCD TV. It is about 5 yrs old. Any advice?
  • 557 Answers
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
This is the procedure for resetting the lamp timer. Have you ever replaced the lamp before? The lamps usually never last 5yrs.
Posted on Sep 30, 2009
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
Need to reset the lamp timer
1 turn tv on
2 press vol- on tv and pip on remote at the same time for more than 5 sec a message will appear
May 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
5 yrs old, blinking green then red, replaced lamp 4 months ago
You very well could have problem with the Ballast board that powers Lamp or your Lamp Fan maybe defective and if you need orinagnal hand unit for set Call Encompass Parts Distrubtion or Go to their website type in Model number they will list Parts /Prices for your model.
1-800-638-3328 Mats Electronics also sells handunits .To reset timer
Hold VOL- on front of TV and Menu on hand unit at same time for 5secs
if this does not work try it in reverse Hold Menu down on TV and Vol- on hand unit. Check your Lamp Fan see if it quits running while turning set on,if it starts and stops it is defective, other wise Follow wires that Lamp plugs into it will connect to Ballast board that powers Lamp CK it Problem M/B Ballast Board.
Feb 17, 2010 | Panasonic PT-52LCX65 44" HDTV
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
I had the bulb blow out in my Sony 60" projection TV. I replaced the bulb and with in 2 weeks I had the on screen notice appear that the bulb was failing. I returned that bulb for another one but the on...
Have you reseted the lamp timer of your tv? if not, you should do it, because it's just adding more and more hours to it to the ones it already had and it's indicating the tv that the lamp is going out, reset the lamp timer and you should be fine, if not, it's probable you might have a defective ballast which are not expensive, they're way cheaper than a lamp, they're running around 70 dlls
Jun 29, 2009 | Televison & Video
HOW do you reset the timer>? the lights on front of the tv flash 3 gree then 2 orange. Says to replace lamp,which I did then reset timer...HOW?
press "menu" button, scroll down to "special features" and press "ok" button, scroll down to "reset lamp timer" and press "ok" button, you will notice the "no" change to "yes" and press "ok" button, you will notice "yes" change to "no", this will reset the lamp timer
Mar 20, 2009 | Vivitek V37655 56" DLP TV
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
137 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
