Question about Palm Treo 650 Handheld
How do i manually program my Treo 650? - Palm Treo 650 Handheld
SOURCE: Treo 650 phone doesn't work
check it battery
Posted on Feb 14, 2007
  • 537 Answers
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
SOURCE: lost speaker on my Treo 650
This problem usually occurs when the headset jack is busted. If there is sound through the headset but none when you plug it out, then a busted or faulty headset jack is definitely the culprit.
Posted on Apr 29, 2008
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account respetadong_pogi@yahoo.com i hope you can help me too.
Posted on Aug 16, 2008
clark_styx
  • 282 Answers
SOURCE: treo 650 change from chinese characters to English
try doing a hard reset and it should give you language options after that, if its not giving you language options,the rom might be chinese only,you need to flash the rom to an english version.
Posted on Dec 08, 2008
Hi how to unlock my palm 650 to used outside of USA
You can use the Unlock code to Unlock Your Palm-One Tero 650 model Phone,You can get the Unlock code from here
Wickedunlock and follow the instructions and Unlock it step by step..
Palm One Treo 650 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Palm One Treo 650 mobile phones. If you enter over a certain amount of wrong unlock codes on your Palm One Treo 650 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Palm One Treo 650 with an ACCEPTED SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application",
3 - Type on Virtual Keyboard *#*#CODE#,
4 - Select with PEN "Numer" and Palm One Treo 650 will show that it's unlocked now!
or
1 - Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
2 - Enter the Unlock Code we send to you.
or
1. Remove Palm One Treo 650 battery, unplug cable,
2. Switch ON your Palm One Treo 650 with a NOT ACCEPTED SIM Card,
3. 'Sim not allowed' is displayed, click OK,
4. Go to the dial pad, and dial *#*#CODE#,
CODE: The unique unlock code for your Palm One Treo 650.
ACCEPTED : We mean, to use a sim card from the network your Palm One Treo 650 is locked to.
NOT ACCEPTED : We mean, to use a sim card from a network other than the network your Palm One Treo 650 is locked to.
Jul 10, 2011 | Palm Treo 650 Smartphone
Unlocked Treo 650 wont send text messages
I have the same problem using an unlocked Treo 650 on O2(UK).
One thing you need to do is make sure that the Message Centre Number is set correctly for the SIM network you are using. Get the MCN from the internet, then on the Treo Messaging > Menu > Options > Preferences > Network > Manual > Edit to check/set the MCN.
Oct 01, 2009 | Palm Treo 650 Smartphone
PHONE BOUGHT ON EBAY-FLASHED FOR CRICKET-CAN'T BE PROGRAMMED
you have to dial #*#000000
This will pull up the setup screen.
You will have to get the following info from cricket...a store will tell you.
MDN #, MIN#, and CID#, leave the NID# blank.....then u should be ready to go.
Nov 15, 2008 | Palm Treo 650 Handheld
TREO 650
Im not sure about your model but, select them all first and then add to sim?
You might need a program todo it for you thought.
May 01, 2008 | Palm Treo 650 Handheld
Installing the memory card in my Treo 650 cell phone
there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)5deba98.jpg
You can back up your Treo to either your PC or your SD
card. If you back up to your PC via hotsync, then there is a nice freeware which
can be installed to your Treo that is called SyncAll (all one has to do is right
before the sync, open the program and click "force all to sync"), and it will move
all the files, including preferences and such that don't normally get sync'd. If
you backup to your SD card, there are numerous programs for accomplishing this. It
is important that the number of backup-to-SD programs are limited for the Treo 650
due the NVFS file system. You can try THIS ONE for example - it's free.
Apr 26, 2008 | Palm Treo 650 Handheld
Check out what is available on the Palm website: www.palmone.com
Go to support, downloads, then pick your model (Treo 650) /and/ your service provider.
Mar 05, 2008 | Palm Treo 650 Handheld
Unlock code for palm treo 650
sign up at mytreo.net I was able to get an unlock code program for my treo 600 there
Jan 06, 2008 | Palm Treo 650 Handheld
WINDOW MOBILE 5
You can get a large sd card and install all kinds of programs onto that, via the bundled 650 software and using your desktop computer.
Dec 26, 2007 | Palm Treo 650 Handheld
Synching treo 650 with 600
In a nutshell, make sure you have a recent synch to your PC of the 600. Install the Treo 650 desktop software Synch to the username of the 600 Your are done. You should rename the Treo 600 or hard reset it (you will get data corruption if you synch two devices with the same username to one PC). If you are paranoid, you can make a backup copy of your c:\program files\palm\ folder to begin with. This contains most of your settings and extra software on the 600. As you are an Outlook user, your personal data is probably in a PST file or it is stored in Exchange.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
535 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
