Sanyo 13 or 14 inch TV, C 03 shows on the screen, how to remove
C 03 shows on the screen and I can't fine out how to remove it from the screen, the picture is good sharp and good color, I got the set second hand and I have no remote for the TV, I use the buttons on front of the TV to make any changes, it is hocked up on a satellite now for TV and I have every thing on channel 3 because a local tv ststion is on channel 4. I hope this is the information you wanted.
thanks bilg427
I can't able to oscillate the horizontal output of sanyo tv model no. ST-14se1 tho power indicator keeps on blinking only what component should i consider to replaced?
Posted on Oct 26, 2009
Dp46849 Screen goes black after 10-15 minutes
This info was given to me by a HAM Radio friend that repairs TV's For a Living.
Disassemble TV, clean all boards from dust, unplug/replug all connectors,
most are really small, be careful, try TV again. Out Same Model TV started off the same, RIGHT bottom of screen/shadow when TV was on for awhile, since then has got worst, like 2 shadow boxes showed up, now upon startup, TV is screen is covered w/vertical lines, shut off the TV once or twice and works fine until next startup. If the above does not fix TV, look at the top of TV from Back Panel Off, Top-Center is a board called T-Con board, replace it. All the info for this board replacement is on the Bar-Code Laabel and Board itself, ie; T370HW02 VC CNTRL BD, 37T04-COG, FX-5546T03C22 (orC21)-964-0000NMP-00629-03 this board is Mgr By AU Optronics. GoTo For Parts/Pricing, they have 180 warranty on parts, aprox $45.00 for T-Con . http://www.shopjimmy.com/auo-55-46t03-c22-t-con-board.htm. He stated It IS Very Rare That The LCD Screen Itself Would Be The Problem. Right now I have Our Sanyo DP46849 apart
laying down on a bed, had to remove Base Pedestal to remove back cover,
There is a smaller cover, 2 screws u can remove to gain access to the turner board and power supply, there are 2 more boards hidden, before u remove back cover from front panel, untape wire leads from back of LCD Screen and unsnap the 2 torrid coils, black plastic things wires going through, these torrid/ferrit coils are mounted on a snap-in base, w/very small screwdriver they will unsnap from plastic base in 4 corners, if the base breaks from panel frame, just hot reglue back in place when are repairs are final. The 2 panels will seperate eaisly, if not you have some maore screws left to remove. Our TV was little dusty inside on the power supply board and alot of dust collected on some big transistors, 3 lead/legs, I'am hoping this caused the power problem @ start-up, going to clean all bard then reconnect all leads/cable, ect and retry, If no work will replace the T-Con board. Hope This Help's All
Dec 05, 2011 | Sanyo DP46849 46 in. HDTV
Recently my grandmother hit a button and now there is a C 03 always on her screen . How do I remove this?
I assume this means "channel 3." In this case, it is likely that your grandmother pressed the "display" button, which shows all of the relevant information on the screen. To remove this, try hitting the "display" button a few times until it goes off. This may not work, but it's definitely worth a try. Good luck! Der Strom
Apr 05, 2010 | Sanyo DS24425 24" TV
C 03 on screen
call tech support
Mar 11, 2008 | Sanyo DS31590 31" TV
Sanyo 42 inch flat screen tv numbers on screen
contact the manufacturer there may be a software fix for the unit. or you may be in service mode which they may be able to help you get out of with a series of button pushes.
Feb 08, 2008 | Televison & Video
TV NOT WORKING
I don't know if you are saying that you are not getting a screen or that you are not getting picture. If you are not getting picture but have light on screen, try autosearching, I mean tuning, if you are not getting any light on the screen your tv is dead, you should get it repaired.
Jan 18, 2008 | Sanyo DS31520 31" TV
Need help please
I fixed this by pressing TV on my universal remote and then pressint INFO. It went off.
Dec 10, 2007 | Sanyo DS25390 TV
Televison & Video Logo
551 people viewed this question
Top Televison & Video Experts
Electro Med Services...
