Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
Leaks underneath approx 1 quart water, from pan not from waterline or drain hose
    Problem Solver:
  • 15 Answers
If dishwasher has been used,then sat for awhile(months)then main could have dried out,maybe you have well water with alot of rust,or sediment to cause this.
Posted on Sep 30, 2009
Not hooked to water but water leaks from under the unit What to do?
There is a drain hose that empties the defrost water from the cooling coil and drains into a pan located at the bottom of your unit, where it evaporates. Check to see if this drain hose has popped out of this pan, or possibly the pan is cracked.
Sep 19, 2014 | Kenmore Refrigerators
How do you replace a water pump
totally depends on year make and model. Let me know and I could help
Apr 25, 2014 | 1995 Toyota Camry
I have a GE Profile Arctica refrigerator - water is leaking from the punctured plastic hose going up to the water filter (plastic hose from the bottom of the solenoid goes into refrigerator assembly)....
Good day!!!!
Refrigerators with a defrost cycle drain the melted water from the evaporator coils through a tube or a hole into a drip pan underneath the refrigerator. The water usually evaporates, but most times the pan is removable and can be drained. If this path of water is blocked at any point because the drain hole or tube is crimped or clotted with anything, it will back up inside the refrigerator area and try to find a way out, usually under the crisper drawers. To fix this, clear the obstruction in the drain tube. The drain pan at the bottom of the refrigerator can overflow or get old, crack, and develop a leak. Other times, mold can grow in the drain tube and clog it. Most refrigerators have an ice and/or water system built into them. This means that you have a waterline attached to the back of your refrigerator and it comes out as ice or cold water. Anywhere that water travels through the refrigerator and freezer can turn into a leak. To find the leak, you need to follow the tubes that carry the water through the appliance and make sure that all connections are tight.
Leaking containers or spills in the refrigerator can be misdiagnosed as leaks. First make sure that there are no puddles of juice, milk, water, etc. on one of the large capacity shelves.
I hope this solution will be helpful...Thanks for using fixya..
Aug 31, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I dont know where the reservoir is in my air conditioner, is there a hose to hook up to drain the water becuase now it is leaking on my floor
On the Air-To Air Model, the majority of the moisture is supposed to exhausted out the exhaust hose and out the window. However, if it is extremely humid, the water collection tank will capture what is not exhausted. There is no hose, To drain it, there is a removable drain plug on the back of the unit, down near the floor level. You can either drain it in a low sided pan, that is capable of holding at least 1 quart of water. Or you can disconnect the unit and roll it to a floor drain (if you have one) or out doors to drain the water.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | DeLonghi Air-To-Air Portable Air...
Step by step in how to do a oil change on a 93 190E Mercedes Benz
1) Warm up engine slightly 2) Remove drain plug from oil pan - oil drains into receptacle you have placed underneath it. 3) Allow oil to drain for a while 4) Remove the old oil filter and install a new one, being sure to lubricate any rubber seals with fresh oil prior to installation. 5) Re-install oil drain plug 6) Add 1/2 quart less than the total capacity of your oil as specified in your owner's manual 7) Run the car for a minute or two inspecting for leaks 8) Stop the engine, allow the engine to sit for approx 3 minutes 9) Check the oil level on the dipstick and add to the full line. 10) Take your old oil to be recycled
Done!
Feb 18, 2011 | 1993 Mercedes-Benz 190
Waterleak
is it leaking from the door or from underneath it. If it leaks from the door then you need a new seal. If it is leaking from underneath it could be the waterline coming into the dishwasher or the drain hose. Both fittings are underneath the dishwasher and are accessible through the lower panel on the face. Let me know if you can figure out where the leak is coming from and I will help you solve the problem.
Thx
Jul 31, 2009 | Dishwashers
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
69 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
