Question about GE Wireless Optical Mouse
My new GE 98812 ergonomic wireless mini mouse isn't working anymore. It was very simple to set up for the first time last night (right after I bought it), but today it won't connect at all, even though the "device is working properly." How do I fix it?
  • elizabeth Aug 16, 2013
    I WANT TO FIX NOT BUY i HAVE IT
  • Debbie
    Debbie Apr 09, 2014
    There is no button on the bottom of the mouse -- just an on/off switch. And nothing on the USB plug in device to depress. No idea what you mean.
On the bottom of the GE wireless mouse there is a connect button make sure to push it one time then on the usb there is a connect circle hold it as if you were going to pinch it sounds dumb but I was just having the same problem and I read one of the solution fixes and it said to push connect button on back of mouse and also push it on the usb where it says connect even though the one that you push on the usb stick isn't a button but it is sensed once held with pointer finger and thumb hope this better describes it to fix it
Posted on Mar 07, 2010
  • 12 more comments
  • juanfdixon Aug 30, 2010
    I've been trying to get this mouse to work for months and decided to try once again and found this posting. Finally it works. Thanks
  • mauriprunera Oct 15, 2010
    Thanks, It's working now!!! God bless you
  • garynoff Nov 23, 2010
    this worked. thanks
  • alianniem Dec 06, 2010
    How many seconds should you push the buttons for? I keep trying this and it doesn't work, though it used to!
  • drn1031 Dec 19, 2010
    This worked! Thanks
  • momma_bird00 Jan 14, 2011
    thanks,, i thought maybe i was to download something, it worked right as soon as i bought it,, then 1 week later,, nothing,, thank you for your help,,
  • sdavis97 Feb 05, 2011
    I cant believe this worked but it did thank you so much!
  • fletch1936 Feb 13, 2011
    Great!!!! worked like a charm!!!
  • ihde_terry Feb 21, 2011
    thank you it works u saved me 24 bucks
  • chomypams Aug 22, 2011
    Thank you so much this was really really helpful. it works.
  • johnshiers19
    johnshiers19 Feb 25, 2012
    thank you..it works
  • novice Sep 05, 2012
    Awesome!! Thanks Veronica Flanary!!Add a Comment
    Thanks Veronica Flanary!! Worked Like a Charm!!
  • Darlene Hyman
    Darlene Hyman Mar 31, 2013
    Thank you so much! I had no clue how to make this work; no instructions came with the mouse! Now I have a new mouse for my laptop! Yayhhhhhhh!!!
  • 5 Answers
Be sure to press the connect button on the mouse itself and on the piece that you plug into the USB port. You must push both buttons.
Posted on Oct 14, 2009
  • 2 more comments
  • hoosiermama8 Nov 07, 2010
    Thank you for posting in "dummy" termology! I understood YOUR instructions well!
  • suchabadboy Dec 21, 2010
    I have tried this several times and its still not working. Help!!!
  • TShooter59 Feb 05, 2011
    ***Very Important*** GE Wireless Mouse 98812
    You actually need to firmly depress the USB connector inserted into the computer for about 3 seconds between your thumb and index finger, you will then notice a small led begin to flash on that device, Then you should press the Connect button on the mouse, the mouse should then be functional.
  • toussaint528
    toussaint528 Oct 21, 2013
    The best solution is above^^^
The BEST SOLUTION above may sound crazy but it works.
My MOUSE now works doing actally what it saids.
Thanks so much.
br
Posted on Apr 12, 2010
  • xeekee Feb 14, 2011
    I have to say that i 'smiled' while reading 'your' solution ' ... now i have to say IT WORKS !!! ty ty ty !
  • 3 Answers
Wow! it worked, thank you, thank you, thank you!
Posted on Mar 19, 2011
Still doesnt work
Posted on May 01, 2012
Thank you! I would never though about the little circle in the USB htnaks is working now! :)
Posted on Oct 05, 2011
My mini98812 when i plug the usb in and push the button on it ,it flashes.then when i go to push the connect button on the mouse the light turns red does a quick flash then remains on.it wont work!!the red light remains on.can i reset it?
Posted on Aug 21, 2011
  • matt_ybarra
    matt_ybarra Apr 06, 2013
    mine is doing the exact same thing as yours and idk how to fix it please help! It was working just fine yesterday. I am running windows 7 ultiamte 64 bit through bootcamp on a macbok pro 13"
  • Anonymous Apr 05, 2016
    what is your operating system? chances are you are having mouse Driver incompatibility issues?
    probably Windows Vista, 7 and newer ones might not work right with older USB mouse devices ...
    what about weak batteries? that's the problem with mine apparently ...
    i used this mouse with Windows XP on a laptop when i got it in the old times, it worked but stopped working after a short while ... even with new batteries ...
    i also tried rechargeable batteries in order to save on costs, and this mouse loves using a lot of power ... now, although the mouse starts and may work shortly on some systems, it doesn't work for long anyway, which could be related to the voltage rating of the rechargeable batteries that is a bit lower than regular batteries, although the amperage is higher ...
    overall, sounds like there are some serious flaws in the mouse design and build itself anyway ...
I had it working for a day but does not working anymore ergonomic wireless mini mouse 98548 even tried another computer
Check to see if the driver are installed and installed correctly, if that is done, check to see if the usb transmitter is fully seated in. Try doing this when you are already in your operating system.Usually the hardware icon would pop on saying hardware found etc. If there is led light on the usb transmitter, is it on? if not your transmitter is bad, secondly you want to also press the little button under the mouse so the tansmitter can detect it. If this still doesn't work, then the usb transmitter is bad or the mouse transmitter is bad. You will need a new wireless mouse.
Jan 31, 2011 | GE Televison & Video
My 98812 mini mouse does not Put new batteries
Try plugging and unplugging the usb adapter a few times first. You might also try it in another usb port, sometimes that will, miraculously, fix it. Then, maybe reload the software. Good luck!
Mar 19, 2010 | GE Wireless Optical Mouse
My 98812 mini mouse lights up but will not move the pointer i have vista
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | GE Wireless Optical Mouse
I have a new GE Ergonomic Wireless Mini Mouse - Model 98811. Can't get it recognized by my computer.
Be sure to push the connect button on the mouse and squeeze the button on the part that plugs into your USB port.
Sep 05, 2009 | GE Wireless Optical Mouse
98811 mouse wont work
The GE 98811 ergonomic Wireless mini mouse is a HID compliant mouse you will need to change the setting to use this mouse. This is what I would suggest:
Go to device manager
Go to the unknown device
Manually pick a driver
Mice and other pointing devices
***Change to a HID compliant mouse***
Then press the connect buttons on both pieces of hardware and the mouse should work
Hope this helps, it took me over two hours to get the mouse working. Very frustrating!!
Sep 03, 2009 | GE Wireless Optical Mouse
GE Wireless Optical Mouse Logo
11,668 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
