Toshiba laptop stuck
I have a toshiba laptop. I'm not sure of the model number.I usually just close my laptop instead of shutting it down or putting it into hibernate. It has worked fine up until two days ago. I opened my laptop, and it froze on the system resume. Now whenever I start up it says 'resume system resume'' or ''delete restoration'' I can't select anything. It's like it's completely frozen. I've tried pulling out the battery, and shutting and restarting multiple times. Any ideas on what to do?
  • 40 Answers
Try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Posted on Sep 30, 2009
Cannot get my Toshiba L505 Laptop out of Hibernation mode
you may find this helpful try it soon and let me know if it works
click here
May 16, 2012 | Toshiba Satellite L505-S5966 Notebook
I have a Toshiba Satellite L305 S5907. Every so often it completely shuts down right in the middle of something. What causes this?
Usually a complete shutdown like that indicates a heating issue. You can try http://www.hmonitor.com/ to monitor the temperatures if it's supported on that system. Toshiba's are kind of notorious for fans on the bottom of the laptop. Try using the laptop on a table instead of "your lap", or maybe invest in a laptop cooling pad. (look on amazon for some with good reviews.) It is possible that you have a bad fan as well which would need to be repaired.
Jun 24, 2011 | Toshiba Computers & Internet
On/off switch keeps blinking
The on/off switch usually blinks if you have put the computer into hibernate instead of shutting down, or with laptops closed the lid before it has fully shut down. Restart your computer and if it says resuming windows instead of starting windows then this is what has happened.
Hope this helps
John
Dec 03, 2010 | Computers & Internet
Hi guys I have a Toshiba Laptop Model TE2300 on shut down a screen comes up saying END PROGRAM- SAMPLE this stops you shutting down what is the problem and can it be fixed thankyou Kind Regards Mark
the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
Nov 14, 2010 | Toshiba Tecra TE2300 Notebook
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby modes....windows hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
TOSHIBA A300D 13C LOGGING OFF ISSUES
Have you fixed this problem
if not go to control panel display
then screen saver then power or power options
make sure you have all the settings correct then press apply
you can put it on never for system standby
let me know how things are going
Jan 14, 2009 | Computers & Internet
Computer shuts down on its own
Usually what gives these types of sighns is that the laptop is overheating.
It hasn't cooled down yet and that's why it will continue to reboot a couple of times it's a safety catch so you don't fry anything within the laptop.
A couple things you can do put it down on a hard surface when in use do not cover the bottom vents that let's the computer breath and cool down.
Also they sell in many stores you will see laptop coolers.
They are flat and light which you put your laptop on there's fans on the bottom that blow up at the bottom of the laptop to keep it cool
I use one it let's the laptops life last longer plus it don't burn the legs or heat up the legs while on the laptop.
Happy Holidays
Dec 25, 2008 | Toshiba Satellite M205-S4806 Notebook
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
