Question about InFocus SP-LAMP-LP3F Projector Lamp for LP340, LP340B, LP35
I have the same issue minus the clicking
The lp340 powers up...the led goes green for a few seconds then flashing amber
  • 2,237 Answers
Check the lamp for bulges, black spots, or fogging. if that's ok, check the colorwheel. if that doesn't spin, the lamp won't light. if they are ok, replace the ballast.
Posted on Jan 07, 2010
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Another dead Vizio... P50HDM
95% Y and Z sustainer boards since you alweady had red pixels.
May 15, 2008 | V, Inc. Vizio P50HD Plasma Television
Projector will not fully startup
the colorwheel is bad. and what's worse, you can't get parts for the lp340 anymore.
Dec 01, 2007 | InFocus SP-LAMP-LP3F Projector Lamp for...
FActory reset went horribly wrong
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Oct 25, 2007 | NetGear WGR614 Wireless Router
InFocus SP-LAMP-LP3F Projector Lamp for LP340, LP340B, LP35 Logo
143 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
