I've heard of other people refilling the cleaning cartridge with other solutions rather than buying a new one. I understand the genuine article contains a lubricant as well as a solvent. You might have to manually lubricate the cutter head if you use a solution that does not include lubricant.
From my understanding of chemistry, the cleaning cartridge label reads SD alcohol plus detergent. Translation: Slowly Denatured (80%+) Rubbing Alcohol plus mild detergent. I haven't had a problem yet. I see no rusted blades. Cytherian's advice is well taken; those cartridges are costly for what they offer.
Do NOT use any other fluids in the cleaning base other than what Braun supplies.
However, be advised that Braun encourages you to use this solution far more than is really necessary. I just tap out the whisker debris after each use, then use the cleaning solution once every couple of weeks. After cleaning, remove the cartridge and cap it off. You need to do this otherwise the cleaning solution evaporates. The result of doing this? I install a new cleaning cartridge about once a year, rather than once a month!
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
The stands for these Syncro models are notorious for breaking. If your shaver charges direcly fom the cord but not the base, it sounds like there is an electrical problem with the base...probably the circuit board is bad. Parts that you would need to fix it are no longer availale from Braun. You will need to replace the unit. You will find a replacement at shaveroutlet.com. See link below
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
The pump is bad. This part is unavailable. Your only option is to buy a new base. They are available for model 7526 at shaveroutlet.com. See link below
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br />
<br />
arm only<br />
<a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br />
<br />
<br />
complete base<br />
<a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
It is probably plugged up at the base. Take the cartridge out and turn it upside down> next clean the openings with a cotton swab< it make take a while as it can get gummy> That should fix the problem
