Question about Gateway M-6846 Notebook
My son poured water on my gatewaylaptop. I took
My son poured water on my gatewaylaptop. I took it apart, let it dry & reassembled. Only a few of keys work properly, currently using on-screen keyboard to type. What else can I do?
  • Gateway Master
  • 32,281 Answers
Buy a replacement keyboard or use an USB keyboard and connect it to the USB port.
Replacement keydoards are available on the Internet, I purchased one from Yall Store - use this link to their WEB site :-
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on Sep 30, 2009
  • 788 Answers
You will end up trashing the laptop if you don't have it serviced.
If water has made it past the keyboard and to the motherboard, you will be done.
Don't use the unit, find a local service and repair, they may change the keyboard but you will have a working unit when it returns.
Keyboard for that unit is about $18.00 New. The inspection and blowout, another $50.00
Peace of mind.0
After cleaning my kitchen aid mixer it won't turn on
You must have water in the controls, use a blower dryer and dry it all out or just let it set for a few days and see if it works again, if not you must have done something wrong assembling it, what that might be is really hard to say.
Oct 17, 2016 | KitchenAid Kitchen Aid KL26M8XOB - Pro...
How to take apart canon pixma 432. Spilled soda in it, need to clean inside.
Hi Daniel,
Let me say, up front, that I am not a printer guru. My background is in biomedical electronics, but this procedure works in most applications. Take distilled water and pour a small amount into the area where the soda was spilled. Wait a few minutes to allow the water to dissolve the dried soda. Then pour in more distilled water to flush out the residual soda. Allow to dry. The water should rinse out the soda, and when it dries it will leave no contaminates of its own. This procedure works well on medical devices such as telemetry transmitters and cell phones that have been spilled on. I hope this helps. Thanks for asking Fixya. Dan
Dec 04, 2014 | Office Equipment & Supplies
Mac air ratchet repair diagram
What is the model number of the tool
Dec 05, 2013 | Air Tools & Compressors
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
My son poured water on my laptop. I let it air dry for about 3 days. This is not covered by the warranty. it powers up but the screen will not come on. what do I do?
First thing is to not try powering the laptop on after the water fell on it. Next, you should remove the battery off the laptop immediately. When this is done, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of water on the circuit boards & on other components. On circuit boards, water damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no water seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the water fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Sep 09, 2010 | HP Compaq Presario CQ61410US Notebook
My panasonic vortex, when in cleaning mode, does not dry and does not **** the water back into the holding tank
Probably due to wire being cut inside cleaner. My cleaning system charges, and the indicator lights for cleaning and charging light up, but I don't believe water is flushed through system. Took apart and found broken wire. Working to replace wire and reassemble, but having issues with disassembly so I can replace wire.
Nice razors, but not as durable as the older models.
Aug 18, 2010 | Panasonic Vortex HydraClean Men's Electric...
My Bissell ProHeat 2x is pouring water out of the bottom anytime it's turned on. I had it in the shop for no water, took it back again for the same problem, took it back again because it had no suction,...
Took the unit apart and discovered my heater had small pinholes in the metal and they had put in silicone, instead of a gasket, which didn't seal. So much for the place I took it to "saving" my heater for me. I repaired it myself by getting a few o-rings and a seal from the hardware store. As for the "holes" in the bottom - a little marine fixative.
Nov 03, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Screen got sprayed with a lot of cleaner (my son) so I took it apart and dried it out. Now the picture only looks good when sitting right in front of it, it almost looks like circles in the screen. Is...
you can try cleaning them with just damp water and then drying them once there dry reassemble them and see
its a good bet you should probably be looking for a set of screens
Oct 25, 2009 | Toshiba 42H83 42" Rear Projection...
Can't reassemble top of carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggh
Jul 29, 2009 | Bissell 1699 ProHeat Clear View Upright...
Wet dash
There's still water in it. You'll need to take the battery out and let it dry another two days. I got my phone wet one time and it took a week before it worked again.
Oct 15, 2007 | T-Mobile Dash Smartphone
Gateway M-6846 Notebook Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
