Question about Frigidaire GLTF1670A Front Load Washer
Smely Clean Clothes
After washing clothes, they still smell, especially the towels.
We had a similiar problem. It was mildew in the washer and in the fabrics. We ran two or three empty loads with some bleach added in, and we leave the door open so the drum dries.
The towels and clothes we hung out in bright sunlight. The UV rays kill the mildew.
Posted on Dec 27, 2007
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washed clothes still smell dirty
If you don't leave the door open after each use you will get a musty smell and mold will build up in the bellows. also you need to wipe the bellows dry and the door glass dry as to not get a build up of soap residue on it which will eventually make the door leak. Also, only use one or two tablespoons of soap, not what the soap manufacturer says on the package.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes, especialy towels smell moldy no matter
Same problem here, heavy lime in the water, we had to change to Purex powder with Renezit. Problem is gone!
Jan 29, 2010 | Samsung Washing Machines
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes don't smell clean; how do I get my clothes to smell clean? Especially my towels.
Go to YouTube, type in "smelly washer".....really. You'll find several tutorials there; one of them is what you need.
Regards, --W/D--
Aug 01, 2009 | Kenmore Washing Machines
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Clothes just don't seem to smell clean
We have the same problem with the 3200, I have run a cycle through with no clothes and adding bleach instead of detergent.
Seems to help some.
Feb 28, 2008 | Bosch WFMC 3200 Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Frigidaire GLTF1670A Front Load Washer Logo
175 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
