Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Ge refridgerator pss26std ss
Ge fridge pss26nstd ss we are having problem with the temperture control. fridge on 52 degrees and freezer on 12 degrees. don't know how to set the tempertures?
the dr
  • 447 Answers
SOURCE: fridge freezes
brand??? model #//
Posted on Nov 27, 2007
  • 531 Answers
SOURCE: GE Profile refrigerator freezer remains in defrost mode
once it go to defrost the fan in freezer will be off when it come back to freezing should be on some takes a second or two and then fan come on check fan switch
Posted on Apr 06, 2009
woodchuck789
  • 4059 Answers
SOURCE: water gathering at bottom of fridge.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Our refriderator (GE Profile) keeps losing its
With a Profile the problem is most times the defrost heater has burned out.I have yet to see the control board be the reason. Look into rear of freezer on rear panel if not defrosting it will have a frost line creeping up the panel wall. The defrost heaters for your model have glass tubes surrounding the heating element and most times one you get the ice melted away yo can see black marks inside glass where it burned out. So if you want to do this yourself unplug and remove the rear panel and defrost with a hair drier to speed things up. It may take about two more days before this begins so plan on saving all you can somewhere else. I know, yea right! Anyway things could be worse. I will list the parts you will need and contact info, Thanks Sea Breeze
Posted on Apr 11, 2010
heatman101
  • 43501 Answers
SOURCE: What should the temperture in the fridge be?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 04, 2010
Model no. pfs23kshss ge profile refridgerator left door does not match up flush on the outside with the right door. we can feel the cold air escapifridge temp was 62 degrees and freezer at 10 degrees
Gotta stop the air loss by fixing the hinges and/or replacing the door gasket. Freezer should be around zero degrees and fridge around 40 or less.
Jun 28, 2015 | GE Refrigerators
Freezer works refridgerator only cools to 52 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
Refridgerator side is set to 34 but temp reads 52 last night freezer was at 20 when set to 0 cleaned coil of dust now reads 0 but fridge side still wont come down it is a GE side by side
your evaporator coil in the freezer behind the rear panel is iced up and cold air cant flow thru ice,defrost the evaporator coil,then check continuity of the heater element under the coil,if its good,then suspect the defrost control,usually located in the refrige side on the upper area
Jul 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
Produce in fridge freeze
hI back at you. Oklahoma USA here and hot. You having cooler weather there? Im not femilure with your climate but the produce drawer should have an air damper that closes off to prevent freezing. This damper may not be closing or the refg may be set to cut off an air movment fan motor and the control is faulty. If the knob you turn dosnt stop a hum when you turn it all one way or the other after 2 to 6 minutes the fan is running all the time and now yuou look for the air damper. On some models there is a motorized damper. Ice could be holding the damper open not allowing it to "dampen" freezer air off. Look in the refg compartment with the crisper trays removed and look for a hole between the freezer and refrigerator side. Could be round or square or rectangle. work the control ans see if air flow slowes or increases. Inspect with a mirror fro Ice or other blockage of the damper door.
Let em know how this works out.
Jun 19, 2009 | Maytag MSD2656G Side by Side Refrigerator
Refrigerator does not maintain 37 degrees
i have seen this problem before its the control board in the back the board is about 150 dollars and it goes every DING DING 5 years lol horrible design of the one that comes on the fridge every ge side by side has this problem  its very easy to replace but have to "ground" yourself before you touch the new control board meaning rub you hands on plumbing pipes, not pvc or copper
good luck if you got questoins let me know
Jun 08, 2009 | GE PSS25NGM Side by Side Refrigerator
GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Jul 28, 2008 | Refrigerators
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
104 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
