Question about Samsung Propel A767 Cell Phone
Water got into the phone
Drink spilled on the propel and it wont turn on
    Guru:
  • 173 Answers
Put it in a bag of rice for 2 days with battery out and battery cover off
it may work
good luck
Posted on Sep 30, 2009
Spilled some water on my phone and now my screen wont turn on. everything else works fine but the screen wont turn on???
Like all water damage on electronics, it is critical to do the following right away: (1).Remove the battery to slow down the corrosion process. (2). Have someone remove the case to expose the circuit board. (3). Assess the damage. It's easy to see where the water/moisture is as you should notice a whitish/greenish deposit at the spill site.
If it's minor, you might be able to clean the damage and resume operation. Good luck, hope this helps.
Sep 23, 2015 | AT&T GoPhone ZTE Maven 4G with 2GB Memory...
Tip
How to get rid of hiccups
1. Get a glass of water. 2. While holding the glass and making sure not to spill the water, bend forward at your waist at an almost 90 degree or perpendicular angle. 3. With the glass in front of your mouth, drink at the opposite side of the glass. If done correctly, this would make you bend your head forward as you drink. It would seem like you're drinking in an upside down manner. 4. After 3 or 4 gulps of water, stand up straight and it's a surefire that your hiccups are gone!
on Apr 26, 2011 | Health & Beauty
My Acer Chromebook wont turn on after a water spill
Power IC maybe damaged by water, try opening the whole system and dry the circuits and body and reassemble and try again, and well last option is always service center..
Mar 19, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
My emachine wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 10, 2012 | Cell Phones
Had drink spilled on remote now it wont work....any solutions?
take the battery out leave the battery out in a sunny place let the remote sit also in a place that gets lots of sun also what might hel is getting a hair drier and using that the heat should get everything all dry in the remote
Jan 06, 2012 | Bose Lifestyle 35 System
When someone calls my i phone I cannot hear them through the reciever. I can only hear them if I turn on the speaker phone. What should I do to reolve this problem?
ore than likely there is some dirt or even a little bit of water in the jack, which is what happen to me when i spill my drink on my precious, but nonetheless that's a simple if it was only a little bit. all you need to do is go to a local store and pick up a can of compressed air a spray a bit in the jack and try it out, it should work if it goes out again repeat i had to do this a couple of times but it works.
Nov 26, 2010 | Apple iPhone 3G
Scan/seek button is stuck "on" and CD's wont eject
Is it stuck with a spilled soft drink or is the radio just locked in the seek / scan mode? If the button is stuck with a beverage residue, try using a q-tip dipped in water to soften the goo. The button should eventually work out. Don't over do the water as it can harm the radio if it weeps inside the cabinet.
Jan 04, 2010 | 2003 Chevrolet TrailBlazer
My daughter spilled her drink in the keyboard and now the computer won't boot up? Is the hard drive ruined? After I try to dry it out will it re-boot?
A spilled drink on a laptop keyboard is usually pretty serious. Especially if it was a drink that had sugar in it (such as soda). If the laptop was running when this happened, you are probably out of luck. Most likely the hard drive will be ok because they are enclosed in a metal casing that should have protected it from most of the liquid, but that's not a guarantee. The motherboard or something on it such as the RAM is most likely the problem. Letting it dry out might help if it was only water spilled on it and it was not turned on at the time. The good news is, if there was any important info on the hard drive, you should still be able to retrieve it by taking the hard drive out and hooking it up to another PC. The bad news is, you will most likely need a new laptop. Several companies make USB connectors for laptop hard drives so you can connect it to another computer. Depending on what type of laptop you have, the hard drive is usually located under a panel on the bottom which can be removed by a couple of screws. If you need more help, just let me know what type of laptop you have, what exactly it does when you try to turn it on, and if you want to try and save the data on your hard drive.
Aug 26, 2009 | Computers & Internet
My phone got wet
pour rubbing achol in it to aborb all the water and let it dry over night.. this should fix it if not it wont do any harm
Aug 11, 2009 | Samsung Propel A767 Cell Phone
Samsung Propel A767 Cell Phone Logo
114 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
