Question about Mitsubishi WS-55805 55" Rear Projection Television
MITSUBISHI HD 1080 PROJECTION TELEVISION 61"
THIS TV IS IN EXCELLENT COSMETIC CONDITION, THE SOUND IS GREAT AND IT TURNS ON,BUT THE ONLY PROBLEM IS THAT AFTER FEW MINUTES OF BEEN TURNED ON THE PICTURE STARTS TO SHOW DOUBLES(LIKE A DOUBLE DIMENSION FACE) NO IDEA WHAT IS WRONG WITH IT. I BELIEVE IT TO BE A 2000 MODEL.
Do you have any solution?
Please help me. Thank you.
  • 259 Answers
The convergence circuit has probably failed and needs replacing of the two ICs called STKs. The normal cost for having this done is around $400. You can repair it by yourself, BUT you must be an experienced electronics tech and advanced soldering expert. If so, you could do the job for around $200 or less. Don’t even think about it unless you have some deep experience with electronic component replacement.
Posted on Dec 19, 2007
  • Rafael Ortiz
    Rafael Ortiz Dec 19, 2007
    Here is some helpful information:
    Numerous sets of the 55807 generation are experiencing problems with the convergence ICs as they become 2 to 3 years old. The problem results in a bowed picture with the colors separated from one-another. The problem usually appears when the TV is turned on, and often goes away suddenly as the set warms up. A light tap on the case can also provide a temporary fix. The problem is that the solder joints connecting the convergence ICs to the circuit board fail after repeated temperature cycles. The problem of course can be fixed by replacing the circuit board, but reflowing the solder joints on the ICs usually provides a permanent fix (at least until another 2-3 years passes). In some cases the convergence ICs need to be replaced.
    The repair has 2 major phases: Removing the board and resoldering or replacing the ICs. The circuit board is a typical low-cost consumer product: One layer, single-sided, with small, but not minature geometric features. The lead spacing on the convergence ICs is in the one-tenth inch ballpark. The soldering work is not particularly difficult for someone with experience. Removing and replacing the board is the more difficult of the tasks, and is what the rest of this post deals with.
    Should you do this job yourself? If you have soldering experience with similar PC boards, the patience to deal with the mechanical disassembly and reassembly, and are willing to risk breaking something and making it worse, then you're a good candidate to give it a try. Small hands are a plus. If you don't have the experience this is not a good learning project. For the first time I estimate it will take 2 hours to R&R the board, and 30 minutes for the soldering. I imagine that could easily be cut in half the second time.
    OVERVIEW: The TV main chassis consists of 3 large circuit boards mounted to a plastic frame in the bottom of the cabinet. The convergence ICs are on the center board, attached to the large heat sink in the middle of the board. There are 2 of the ICs, and they have 18 leads each. The board is held to the chassis with 10 screws. 3 of them also hold down the large heat sink, 2 of them hold down the metal cover at the rear of the board near the A/V input panel, and 5 of them just hold down the board.
    REMOVE THE CHASSIS AND/OR THE BOARD? The entire chassis can slide out of the back of the cabinet. If the chassis is out of the cabinet, removal of the board is much easier. But it appears that the IC solder connections are accesable without removing the board from the chassis. What makes this an unattractive approach is the huge number of cables and connectors that have to be dealt with to remove the chassis. It is possible to remove the board while leaving the chassis in place, but physical access to some parts of the job is very difficult. What I concluded was the best approach is a combianation of the 2 approaches: slide the chassis out a few inches (leaving most of the connectors intact), then remove the board.
    MAJOR PHASES OF THE JOB:
    1. Unplug the set.
    2. Remove front and back access panels.
    3. Slide the chassis out a few inches.
    4. Remove the large heat sink.
    5. Remove other mounting screws.
    6. Remove cable connectors.
    7. Remove board.
    SLIDING THE CHASSIS OUT
    Remove 3 screws at the rear of the set, disengage 2 plastic hooks at the front, and slide it back. You will almost immediately be stopped by streched out wires, and you need to undo cable guides and unplug connectors as necessary along the way. Try to slide it 6-8 inches back without having to undo too much wiring.
    REMOVE THE LARGE HEAT SINK
    It's tempting to leave this for the last, but it has to come off anyway, and doing it now opens up a lot of space that makes the other jobs easier. From the front remove the 3 screws and the horizontal piece on the front of the heat sink. Then remove the 3 screws that hold the heat sink to the chassis. Note the ground wire under the middle screw. I found it easier to do this from the back, and a mirror can be helpful.
    REMOVE OTHER MOUNTING SCREWS
    2 on the front edge of the board, 2 on the rear edge, 1 in the middle, and 2 holding the metal cage on the rear of the board near the A/V input panel.
    REMOVE CABLE CONNECTORS
    Don't worry about mixing up the cable connections as they are all marked. It may be difficult to pop the 5 ribbon cable connectors (if you think there are only 4, look harder under the plastic bracket holding up the A/V input panel). When I tried to pull them by their little plastic ears it looked like the ears were going to break off. I ended up levering them up from the circuit board with a small screwdriver between the connector and the board. There's a small protrusion on the underside of the connector you can catch with the screwdriver. Popping the connector under the plastic bracket can be a challenge!
    REMOVE BOARD
    The hard part is over now. Release 2 plastic tabs at the front of the board, tilt the front up, pull it forward a bit to disengage the rear edge, and you've got it out.
    Installation, of course, is the reverse of removal. Cleaning up the tangled mess of cables at the front of the board can be frustrating, but with a little time it looks as good as new!
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
How do I get 1080 with my tv?
You will need to connect an 1080p hd device to a 1080p tv via an HDMI cable.
May 24, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
No color on mitsubishi 1080
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Oct 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
