Just hung sony 46''flat screen tilts slightly measurements =
Just hung sony 46'' flat screen tv on wall,,,all measurements show even, all levels show perfect,,,still tv seems to list to the left by about 1/8 to 1/4 of an inch,,,even the tv shows even on the level, are my eyes crooked???same opinion by 3 unrelated observers...have tried all positions (it is a Simplicity full motion wall mount) and still just off a little,,,went over installation video x4,,,what else could it be?
  • 31 Answers
This is quite common on older houses/buildings and on occasion newer ones aswell, when a house is built a decent carpenter keeps his building fairly level, usually within 1/16th of an inch, but there are times when this exceeds 1/16th of an inch, personally i'v seen houses being built where the whole foudation is off 1/2 inch or more end to end, and on older buildings as time goes by the foundation "settles" into the ground, depending what it was built on the whole building could settle further on one end of the house than the other, this can cause cracks to form in foundations. So if your tv is "level" (be sure to try another level) and your measurments are out, this usually means your house or building isn't level or the surface which you are measuring from isn't level. But be sure to try 2 or more levels to ensure the TV is in fact "level", hope this helps.
Posted on Sep 30, 2009
Testimonial: "we came up with this too-my dec'd Dad a master bricklayer built this house- never made mistakes, glad to know is house settling & not my house thanks"
Kdl 40ex400 logo come own then color bars
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
The word debug is on the screen. how do i take it off?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.
Feb 27, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
Oct 03, 2013 | Universal 40-42 Inch Flat Screen Panel...
Can you give me some advice on, how to mount a 46in tv above my non working fireplace mantle?
You would have to use a mounting bracket specifically designed for the type of installation you describe and it certainly would have to be fastened into the studs behind the sheetrock. A TV of that size will be heavy to lift and install in the bracket
Mar 04, 2013 | Universal Bedroom Mounting Bracket For...
Unit tilted. Lower on right side.
check the screw alignments on the base, if the wrong holes were used putting the base on it will be lop sided
Jun 02, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Television
Some top brands in no particular order are, Panasonic, LG, Samsung, Sony, Sharp, Toshiba. Bear in mind that within any brand, there are budget models, mid-range and top range models. The LCD panels will range in quality based on their price range. Features will improve with price as well. One top feature is 120 hertz refresh rate leading to very smooth motion. You may not require such smoothness. Size is probably the most overlooked consideration. Take the screen diagonal measure and double it for the closest distance the screen should be from your viewing location. Three times the screen should be the maximum. For a 42" screen it might be 42" x 2 = 84" or 7' minimum and 42" x 3" = 126" or about 10' maximum. Measure your existing viewing distance, go to a Best Buy and stand at that distance to see how it might look in your home. Don't get hung up on precision if you are a few inches outside of these guidelines.
If your viewing area is brightly lit from outside light, favor LCD. If you will be in a dark room, plasma TV's are an option, but they will run hotter, draw more power and will be heavier requiring a substantial mount to wall mount them, not a one man job.
Apr 18, 2008 | Sony QUALIA 005 46 in. LCD Television
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
