Question about Frigidaire GLTF1670A Front Load Washer
Whites turn gray
Our whites little by little turn gray even after using bleach.
    Sergeant:
  • 264 Answers
Its not the machine how ever it might be you have a hard water problem if so you should use soda Cristal's they cost about £1.50 a bag only do what it say on the pack do not put to much in it wont do any good to the machine only read the part when it say put in the washing machine ok that should help with the whits
Posted on Jan 05, 2008
I am seeing a line of **** at the top of the drum even if I use bleach on my whites they are turning brown my dark colors have gray color **** on them is the washer too old?
There is a shaft seal under the agitator that may be leaking greasey oil.If your aagitator wiggles at the top .Or take off the agitator and look
Sep 22, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whites are not white
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 44102 Front Load Washer
Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Feb 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
My whites are not comming clean and are not a bright white
I don't know if this is a solution to your particular problem but when we wash whites, first, we wash them twice,with hot water, second, we dont use bleach!!! (this will eventually yellow them). Third, we dont use liquid softner. For the whites we use a softner sheet in the dryer. Since we started to use this procedure I have noticed a marked decrease in areas such as under arm stains in white under shirts. I have some that are 2 years old and have no stains or yellowing like this. Hope this helps
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Red t-shirt has run all over the wash. now have pink socks, pink backgrounds etc
did you dry any of this load in the dryer? If you did, the color is set you wont get it out.
If not rewash everything, Except the red t shirt! in the Hottest water the clothing can take. If its whites use a little bleach. you could also use a color safe bleach on colored items. You may want to divide up the load into similar items. Experiment what have you got to loose.
One time we washer a gray sweatshirt with a red sweatshirt, why the gray turned Pink! I dont know we line dried it and washed again, The pink came out.
Good luck
Oct 02, 2008 | Washing Machines
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Whites going gray improper water level?
I cant say nothing with out a visual check, but gona give you a tip, in the past one client complain the same to me, and was a leaky transmission getting grase in the tube, check that point..good luck
Aug 06, 2006 | Kenmore 43142 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
