Question about RCA P52939 52" Rear Projection Television
No raster i have 170 volts standby mode goes to 140 volts normal when power on
    President:
  • 4,402 Answers
Found this on a different forum
http://www.diybanter.com/archive/index.php/t-143488.html
but there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Posted on Dec 19, 2007
Sony lcd tv model LDM 3000 blinks 6 times and no raster or sound
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Apr 17, 2018 | Sony Televison & Video
I have a 2012 Suzuki 140 outboard.
This can be caused by a lack of fuel pressure, you need to monitor the fuel pressure when this problem occurs.
Jan 02, 2016 | Suzuki Outboards - Zinc 115-140Hp Outboa
WHEN SWITCHING ON MY PANA CRT TV IT MAKES A SOUND LIKE A SQUEEK 7 OR A TIMES AND GOES BACK TO STANDBY
There is short circuited component/s at its horizontal scan output stage circuit. Check the horizontal output transistor first. Check it for collector to emitter, or collector to base, leak. Replace it with the same numebr, and check. If it do not help you, check and replace the Line Output Transformer [LOT]. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Panasonic Televison & Video
How solve my problem w/ lcd sony bravia 32in raster 3x show then goes to stanby the blinks
I will need the model number of the Sony and also how many times does the light blink? Thats an error code so the number of blinks will be linked to a specific area of the TV having an issue.
Feb 10, 2013 | Televison & Video
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Avr 235 power at standby mode but sometime unable to power up, please help. A lot of thanks.
Open the unit and measure the voltage across the reset microswitch on the transformer board (with the unit in standby). It should be a hi signal, over 3 volts. If it is low, below 1 volt (when you can't turn it on) it is sending a constant reset signal to the cpu. Remove the switch and try again. If the problem goes away, the switch was bad. Its a service switch so you don't have to replace it.
Mar 25, 2010 | Harman Kardon AVR 235 Receiver
SONY TV PICTURE TURN GREEN WITHOUT RETRACE
Picture goes to high green with retrace lines that shows picture tube is defective and requires replacement.
Usually in above symptom, TV goes to standby mode and standby light blinks when green raster problem occurred.
New TV is better option because picture tube of KV-34XBR960 would not be available any more.
Thanks.
Aug 14, 2009 | Sony Televison & Video
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
NEC 42mpi plasma tv not working
Check the +170 volt  test point on the power board (not the power filter board, the one that the plug comes into) but the one to the right of that board. It has a 5v test point (TP +5v) , a +170 and a +70. I've found that the +170 transformer goes bad, and won't allow you to adjust the voltage using the pot screw.
Dec 29, 2007 | NEC PlasmaSync 42MP1 42 in. Television
RCA P52939 52" Rear Projection Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
