Question about Refrigerators
The fridge is frozen - the temperature guage says 6 degress celsius but everything in the fridge is frozen solid!!
    President:
  • 744 Answers
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Sep 30, 2009
peyton32034
  • 410 Answers
SOURCE: Frozen Fridge
the temperature controlis most likely bad since you cant control it. the control is the knob you turn to set the temp with. you should be able to replace it yourself fairly easily.
Posted on Dec 21, 2007
22yooper
  • 828 Answers
SOURCE: thermostat not working in fridge
Replace the thermostat.
Posted on May 31, 2008
  • 3 Answers
SOURCE: we own a samsung cooltech
Im no expert, but you can try this, take the back bottom cover off and you will see two drairn pipes going into a drip tray. remove those pipes ( just pull them down ) make SURE they are not blocked ( there is a rubber thing at the top that can close up--- just cut it open ) place a bucket under those pipes and leave your fridge off and the doors OPEN........ it may take a couple of days for ALL the ice to defrost. when you think its done--- leave it a few hours and if there is any water being collected --- you still have ice in there. i was amazed at how much and for how long water kept dripping out of the fridge drain pipe.... the pipe nearest to the compresser is for the frezzer, If the sensor that tells the fridge to get cold is all iced up it wont even try to get cold--- it thinks it is already.
Posted on Jan 03, 2009
  • 531 Answers
SOURCE: Fridge is freezing things when temperature guage is on
check damper control or refrigerator door (ajar)
Posted on Apr 07, 2009
woodchuck789
  • 4070 Answers
SOURCE: Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 08, 2009
Sanyo refrigerator showcase spasmodically freezes up
The temperature controller is erratic and should be replaced.
Sep 10, 2016 | Sanyo Refrigerators
Does the temperature on the capacitors matter because my old ones had 105 degress celsius and the new ones i bought have up to 85 degrees celsius
No,not a problems,if it only 10 or 20 degree of celsius.Ur tv is not in an incloser like a cabinate,right?Because it harder for the heat to disapper,if tv it in a small incloser cabinate.
Oct 11, 2010 | ASUS Televison & Video
Fridge too cold.Freezer OK.
You probably have an issue with one of the following:
* temperature control assembly (controls freezer and/or fresh food temperatures)
* damper assembly (allows air from freezer to fresh food compartment)
Contact an appliance service company.
Feb 26, 2010 | Refrigerators
Cant adjust fridge temperature
sounds like a bad thermostat
Feb 24, 2010 | Refrigerators
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Frozen Fridge
Dec 20, 2007 | Refrigerators
Fridge frozen solid
Usually on refrigerators, the highest setting makes it coldest and the lower settings are warmer, relatively. "6" on my dial says "coldest" - Perhaps this is the case for yours? Let's hope it is that simple
Aug 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
